View Single Post
Old 06-25-2004, 02:19 PM   #3 (permalink)
GSGoinFast
DSM N/T Wiseman
Region: Midwest
Classifieds Rating: (0)
Reputation: GSGoinFast is an experienced, knowledgeable member worth listening toGSGoinFast is an experienced, knowledgeable member worth listening toGSGoinFast is an experienced, knowledgeable member worth listening toGSGoinFast is an experienced, knowledgeable member worth listening to
4) Tap the fuel rail for your fuel supply. i have a 99, so i have and used the test port on the end of the rail. just unscrew the cap, and using a shrader(sp?) valve remover(99 cents at autozone) remove the schrader valve in the test port. then screw on the longer of the 3 lines you have remaining on the testport. some people say fuel will leak out a lot, but i only had a tiny bit come out towards the end of while i was screwing it on. tighten all lines screwed on with a wrench. then run the nitrous line from the back(i assume you knew to use the 6ft line for that) and fuel line from the fuel rail, and run them to the smart box and hook them up to the fuel in and nitrous in ports. be sure the nitrous line goes to the nitrous port, and visa versa.
Offline
Sponsored Links
