View Single Post
Old 06-25-2004, 02:13 PM   #2 (permalink)
GSGoinFast
DSM N/T Wiseman
Region: Midwest
Classifieds Rating: (0)
Reputation: GSGoinFast is an experienced, knowledgeable member worth listening toGSGoinFast is an experienced, knowledgeable member worth listening toGSGoinFast is an experienced, knowledgeable member worth listening toGSGoinFast is an experienced, knowledgeable member worth listening to
2) run the line out the bottom of the trunk, over the rear axle, and to the front of the car. I used thicker wire tiers than what was provided, although im sure the ones provided would work, and i wire tied it to the fuel lines on the right side of the car all the way to the front. then i ran it up to the top. sorry, no pics of the line running to the front, but im sure you can find the fuel lines.
3) Mount the smart box. i used a block of wood, and put velcro sticky pads on the battery and block of wood and velcroed it to the battery. then i ran giant wire tiers around the block and battery to make sure it was on.
Offline
Sponsored Links
