How to install Zex Wet kit on 420a
I just finished up my install of a Zex wet kit on my 2gnt. it was a crash course install that went suprisingly well. no body really had much experience with the wet kit on our cars because apparently its new. but its a very simple install. but im going to write this because the instructoin manual could be the vaguest thing ever. here we go
1) Mount the bottle where ever you like. i mounted mine in the trunk. this part is pretty self explanitory, just drill 1/2 inch pilot holes, and use the 4 bolts, washers, and nuts to fasten the mounting brackets on. drill a hole in the board in the trunk to feed the nitrous line through, and then you can do one of 2 things. you can run the line through the plug on the bottom of the trunk, or drill a hole in the trunk. i drilled a hole to free up some extra line.
