Guys, since I was searching online here today for info on integrating a Greddy TT with an alarm I noticed a bit of misinfo sometimes and no true reference materials for the older Greddy TT. (The ones that came in mostly clear blue I guess type I?)
Since I did get a copy of the install diagram page and the owners manual, and it is no longer available on Greddys website I thought I would post it here for future owners reference.
With cars changing hands, Ebay sales etc I thought this would be something someone including myself will one day need, and I wanted to post it to clear up a couple of discrepancies regarding wiring.
1) 2gs have two IGN wires use them (not an Acc) so your fans run, and connect the alarms ign sensing wire to acc instead to avoid problems. (remote starts see a professional installer)
2) Brown wire is for the Handbrake. However the safety features may have to be enabled, or diabled depending on your use of this wire and disconnecting the battery etc will not reenable them. If you don't know the procedure you may not be able to get the safety features to work.
That being said here are the materials
First I'll post a color document that explains what color wire does what, and what voltage etc should be on the wires you tap. I think some Greddy harnesses were backwards as there were many complaints of the timers turning off when the Greddy harness was used.
Testing the wires for their actual function before wiring the TT into them will always ensure you don't have this problem.
I'll try to post the Manual in a second post as it doesn't want to let me in one post. It will have to be page at a time as otherwise it is too large.
