Please Support RTM Racing
Please Support Rix Racing
Zmann42087's Eclipse GST
Ownership Status
Currently Own
Mitsubishi Eclipse GST
Turbo Type
T28
Build Type
  1. Street
FP Big-28 turbo (ported by FP) | FP 17-psi wastegate actuator | K&N FIPK | Injen IS intake pipe | FP fuel pump rewire | EVO IX fuel pump | EVO VIII 560cc fuel injectors | AMS oil pressure remote sending unit | SS oil feed line | Magnecor plug wires | NGK plugs | GReddy upper intercooler piping | GReddy Type-S BOV | Hahn Racecraft lower intercooler piping | Hahn Racecraft FMIC | Samco 4 ply couplers | JM Fab. SS heat shield | ported exhaust manifold | ported O2 housing | RRE downpipe (cat delete) | Apex'i N1 cat-back exhaust | ARC 1.3 bar radiator cap | Samco coolant hoses | Sparco Torino II seats | Sparco Strada steering wheel | Works Bell short hub | Works Bell Rapfix II (Yoshioka Edition) | Sparco Grip pedals | VIS carbon fiber hood w/Sparco hood pins | Carbonetics carbon fiber sunroof | 6000k Sharp HID kit
Mods-Engine
TopLine 3g lifters. Other than that, just a stock 7-bolt.
Mods-EMS & Logging
Autometer C2 gauges (Boost, EGT, & Oil Press.) | Apex'i SAFC II | PocketLogger w/Palm m105 | Apex'i "pen style" turbo timer
Mods-Drivetrain
Wavetrac LSD | B&M short throw shifter | RRE shifter base bushings | ARC Titan shift knob
Megan Racing coilovers | Brembo EVO IX brake calipers | Ferodo DS2500 brake pads | RotorPros slotted brake rotors | 3g brake master cylinder | JNZ Tuning SS brake lines | Carbing Okuyama front strut tower bar | Pilot rear strut tower bar | DIY rear camber kit | RM Racing 17.5mm rear sway bar | 3g rear upper control arms | Paul Volk rear toe arms | Paul Volk front lower control arms | Bobby Gould front upper control arms | Bobby Gould bump steer tie rod ends | Tanabe front lower tie bar | HardRace compression arms | Compworks fender braces | Prothane motor mounts | Prothane suspension bushings | 18x9 Volk ZE40 wheels | 255/35/18 Continental DWS 06 Plus tires
Parts Wishlist
external oil cooler | ECMlink | EVO III intake manifold
Background
first car and purchased in 2005. Still own it 17 years later.
  • Like
Reactions: SAKJR
Zmann42087
More in 2G DSM
Share this Vehicle
