Please Support Kiggly Racing
XiKeiyaZI's Talon TSi AWD
Eagle Talon TSi AWD
MHi Evo 16g - Fuel Labs AFPR - ARP Head Studs - ARP Rod Bolts - Ported Intake Manifold - Specter intake filter - Solid Intake Snorkel - Braided turbo feed and return lines - HKS SSQV BOV - RC 550cc Injectors - Custom Catch Can - B&M Short Shifter - ETS FMIC - Symborski Shifter Kit - Shifter Cable Solid Bushings - 90' OFH with External Cooler - Coil on Plug - Ported 2G Exhaust Manifold - Stainless Steel Open Dump 02 Housing - Apexi Turbo-Back
Mods-Engine
Polk Built Head - Milled - Composite Head Gasket - Balance Shaft Eliminator Kit - 272/272 BC's - Ported and Polished - Adjustable Cam Gears - Clevite bearings - Titanium Retainers - Dual Valve Springs - 1mm Over Valves - 3G Lifters - 2G Head Ported - BogusSVO Head Mods #1 & #2 - 6 Bolt Swap
Mods-EMS & Logging
Innovate MTX-L Wideband - Electronic Oil Pressure Gauge - Electronic Boost Gauge - Pyrometer - Fuel Pressure - Apexi Turbo Timer - EvoScan/Flash (98 ECU)
Mods-Drivetrain
Shep Stage 2 Trans - XTD 2300# Pressure Plate with Sprung 6 Puck Disk
Drilled/Slotted Rotors - Ingalls Camber Kit - Eibach Springs - Tokico Shocks - 17" DR19's - Falken Ziex ZE912 Tires
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
0.0 lb/ft
XiKeiyaZI
More in 2G DSM
Share this Vehicle
