- Year
- 1995
- Model/Trim
- Eagle Talon TSi AWD
- Transmission Type
- Manual
- Mods-Bolt-on
- ported Evo3 16g, ssautochrome FMIC, tial bov, tial 38mm wg, 3" gm maf and maf translator, cxracing radiator, xtune 3" turbo-back exhaust, evo3 510cc injectors, tubular 3" o2 housing, ported 2g exhaust manifold, battery relocated to hatch, underhood fusebox relocated to passenger side air bag
- Mods-Engine
- frankenstein build 6-bolt swap with nippon 2g pistons/1g rods, evo3 cams, arp head studs, chopped balance shaft, 3g lifters that still tick
- Mods-EMS & Logging
- 3" gm maf, keydiver stage 4 chip, c2 pillar gages, pocketlogger
- Mods-Drivetrain
- fidanza 8lb flywheel, act 2600 clutch with organic street disc, prothane motor mounts, clutch accumulator eliminated, chopped shifter
- Mods-Handling
- only weight reduction, sound deadening material stripped, no bumper supports, no spare, no washer fluid, no cruise, a/c delete
- Parts Wishlist
- carbon hood and hatch, 280 cams, cam gears, forged internals, butchered crank, tre stage 3/4 trans, lsd everything, hx40 or bigger, lighter seats, lighter wheels, upgraded cv axles (can't wait for the back ones to break) and driveshaft
