- Ownership Status
- Currently Own
- Year
- 1998
- Model/Trim
- Mitsubishi Eclipse GSX
- Turbo Type
- GT30 Variant
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- Forced Performance FP3065 BB Turbo.
TiAL Sport F38 Wastegate
TiAL Q 50mm BOV
Walbro 255 LPH High Performance Universal Fuel Pump
A'Pexi N1 Cat-Back Exhaust System (Catalytic Convertor Delete)
- Mods-Engine
- 6-Bolt Engine
Kelford 272 Camshafts
HKS Adjustable Cam (Exhaust)
Ferrea Dual Valvesprings & Titanium Retainers Kit
Brian Crower Valves
Wiseco Sport Compact Pistons
Eagle H-Beam Rods
HKS 1.2mm Head Gasket
Deatsch Werks 16MX-09 1200cc Injectors (Qty: 4)
AEM High Flow Fuel Rail
Fuel Clinic Fuel Pressure Regulator (Mini)
SparkTech Coil-On-Plug System (Plug-n-Play)
- Mods-EMS & Logging
- AEM EMS-2 (2-step setup)
AEM Wideband Kit
Hallman Boost Controller
AEM Serial Datastream Gauge
Autometer Boost Gauge
- Mods-Drivetrain
- ACT Heavy Duty Clutch Kit, 6-Puck Disc
Fidanza Light Flywheel
Megan Racing Lowering Springs
- Mods-Handling
- Konig Imagine Rims "18 (Qty: 4)
- Parts Wishlist
- Garrett GTX4088R Duall BB Turbo
JH Racing TwinScroll Turbo Manifold (T4)
TiAL Sport MVS-A Wastegates (Qty: 2)
HKS Carbon Ti Cat-Back Exhaust System
AEM Tru-Boost Controller
Feal Suspension System
Momo Steering Wheel
Bride Seats
Enkei Wheels RP03 (Qty: 4)
- Background
- When I first bought this car, it was a bad deal. The previous owner of this car did not take really good care of it. It turned out that the Engine had Hyundai Crankshaft installed into it to increase the engine liter from 2.0l to 2.3l. It wasn't that bad to be honest due to the fact that low end torque was there, except for the fact that it had an oil leak inside the combustion chamber due to the pistons raising too high. This also warped the walls of the bottom block of the engine.
I did a complete engine rebuild, with more. While I was breaking the engine in, the coil pack on the Intake Manifold started to melt. This gave me an opportunity to upgrade instead of just fixing. So I bought myself a AEM EMS 2 standalone and Coil on Plug kit along with and a new Fuel system to make sure it didn't happen again.
The tune was only at 17 psi, since the tuner didn't want to go anymore beyond that to be on the safe side. My honest opinion is that, if it is built, why not push it to it's limits. So, my next biggest thing is a Ethanol setup/tune. For now, I'm working on looks. Will try to pretty up the engine more with some nice DYI modifications, new HID/LED Lights, Carbon Fiber parts (Painted ofcourse). Trying to make it atleast look decent. Not into the whole rice look. I like it clean look. Although, having a wide body kit on it wouldn't hurt. There aren't many wide bodies out there that meets my standards.
-Feb, 2015-
Ugraded Injectors to 1200cc, and turned the boost up to 23 psi and a Re-tune.
- Dyno HP
- 365 whp
- Dyno TQ
- 300 lb/ft
- Dyno Type
- Mustang Dyno
- Dyno Shop Name
- PRT Performance, TX
- Dyno Session Details
- It was just one run. Ran it @ 17 Psi.
I will try to run it again at maybe 32 Psi. We will see..
