Please Support RTM Racing
Please Support Rix Racing
VTEC_THIS's Talon TSi AWD
Eagle Talon TSi AWD
Build Type
  1. Street
1G TB : Magnus SMIM : TiAL 50mm BOV : ARC FMIC with 2.5" Piping : 7 Blade HX35 with T3 .63 A/R turbine housing : ERL T3 Manifold : TiAL 38mm WG with Recirculated Dumptube : Hallman Pro MBC : Walbro 255HP : SS Fuel Line from Tank to Rail : FIC 1050cc : Aeromotive AFPR : O2 Eliminator : 3'' Turbo Back SS Exhaust: Varex Dual Chamber Muffler : Prothane Motor Mount Inserts: Mishimoto Aluminum Radiator: B&M Oil Cooler with -8AN Lines : Calan Catch Can
Mods-Engine
2.3L 6 Bolt : Wiseco 8.5:1 1400HD Pistons : Scat Rods : Eagle 100mm Crankshaft : Fluidampr : Fully Balanced Rotating Assembly : ARP Main Studs : ACL Tri-Metal Race Bearings : BSE : O-Ringed Block : OEM Composite HG : ARP L19s : 1G Cylinder Head : BC 272/272 Camshafts : Fidanza Adjustable Cam Gears : Manley Valve Springs and Titanium Retainers : Ferrea 1mm OS Valves
Mods-EMS & Logging
ECMLink V3 SD : AEM 5 Bar MAP sensor : GM IAT : AEM UEGO : ProSport Evo Series Digital Gauges - Boost/Vacuum, Oil Pressure, Water Temperature
Mods-Drivetrain
TRE Stage 3 Transmission with 4 Spider : ACT StreetLite Flywheel : ACT 2600 : South Bend TZ-Series Kevlar Clutch Disk : Jack's Transmissions Transfer Case
Adjustable Ground Control Coilovers with Koni Yellow Adjustable Struts : Baer Big Brake Kit with 13.1" Drilled/Slotted Rotors with Aluminum Hats : AEM Rear Big Brake Kit : 17x8" Enkei RPF1 Wheels : 235/45/17 Hankook Ventus V12 Tires
VTEC_THIS
Comments
3
Rating
5.00 star(s) 1 ratings
More in 2G DSM
Share this Vehicle
