Street Build v8 Hunter
Ownership Status
Currently Own
Vehicle
1992 Dodge Colt
Automatic
Build Type
  1. Street
2g VRSF front mount
Trans cooler
Side exit exhaust
SBR exhaust manifold
HX35 BEP dsm housing
Mods-Engine
Dual valve springs
Comp Stage 3 cams
Stock 1993 7 bolt with balance shafts delted
Mods-EMS & Logging
Evo 8 ecu
2g custom wiring harness
speed density
3x 7" touch screens hooked up to car pc for data logging/gauges
Mods-Drivetrain
IPT shift kit
Kiggly Clutches
Forced shift box
Background
Had a 2g gsx and was sick of getting pulled over every time I took it out... ( went 5 under the speed limit behaving myself.)
Found this 1992 dodge colt in ohio.
Decided that I wanted to do the swap.
I started off just planning on doing a small 16g fun car that could still daily..
To basically a full out race car
interior is gutted no heat/ac
Goals are to be at 500hp
and the vehicle weight to be 2000 lbs.
Comments
There are no comments to display.
autocrossn
Rating
5.00 star(s) 1 ratings
More in 4G63t Swapped
Share this Vehicle
