Please Support Kiggly Racing
Drag Race Build Kyle Henny's Drag GSX
Ownership Status
No Longer Own
Mitsubishi Eclipse GSX
Turbo Type
GT40 Variant
Drivetrain
AWD
Build Type
  1. Drag Race
Archer fabrications Top Mount 6466 twinscroll T4 1.00AR//
Archer fab 3.5" vband side exit exhaust//
Archer fab twin 2" atmos dump tubes//
Archer Fab 4" intake//
MK3 golf radiator//
ETS 4" 2g Ultra Race FMIC//
Tial Q 50mm BOV//
Twin Tial 44mm MVR Vband External Wastegates//
Hallman MBC//,
Aeromotive A1000 FPR//
VIS OEM Carbon Fiber hood//
Kirkey drag seat//
Cipher 5pt harness//
Stock Intake manifold
1g Throttle body
Mods-Engine
Archer Fabrications 6bolt 2.0
2g Head with polished domes and stage1 port//
BC 276/276 Cams//
bc dual valve springs//
FIC 2150CC injectors//
wiseco 1400HD e85 pistons//
Manley turbo tuff Connecting Rods w ARP 625+ bolts//
ARP Head Studs//
ARP Main Studs//
ACL Tri-Metals (main and Rod)//
Felpro PermaTorque MLS Headgasket//
Topline 3G Lifters//
BC adjustable cam gears//
HKS Kevlar Timing belt//
Fluidamper harmonic balancer
Mods-EMS & Logging
95 Eprom ECU with DSMLink V3, Speed Density//
AEM UEGO WBo2//
Auto Meter Boost/Vac Gauge 30+/30//
Walbro 450 STM Rewired -8AN feed -6AN return tank to tank//
Omni power 4 bar Map//
GM IAT//
Apexi Turbo Timer,
AEM Oil pressure Gauge 0-150 PSI
Mods-Drivetrain
ACT 2600 Sprung 6 puck Clutch//
ACT Street Lite Flywheel//
Comp Forged Clutch Fork//
Stock Viscious 4 bolt LSD//
Three speed Scatter Shield//
Shep Stage 3 Trans w/ 4 Spyder Center, EvoIII 1st Gear & Input Shaft//
Solid Shifter Bushings (Trans and Base)//
Magnus transfer case bearing cover//
DG KONI coilovers 650 front 350 rear
Megan Racing Front Strut Tower bar//
Hawk HPS Pads//
Power Slot slotted rotors all the way around//
Rota slip streams 15x7.5//
26x9.5 hoosier QTP//
ARP extended wheel studs
Parts Wishlist
SMIM, 8.50 full cage, s90 74mm,
9.99 Time slip or 150+
Background
TIG WELDER extraordinaire
1/8 Mile E/T
7.323
1/8 Mile MPH
108.61
Timeslip Video Link
Watch Video
Timeslip Photo Link
Timeslip Details
Track Name : Cayuga dragway Toronto Motorsports Park
Nitrous : No
Fuel Used : Race gas
Vehicle Weight : 3000
Tires : Street Radials
Altitude : 600ft
Sponsored Car : no
Dyno Sheet Photo Link
Archer Fabrications
Comments
5
Rating
5.00 star(s) 4 ratings
More in 2G DSM
More from Archer Fabrications
  • AF Evo 9 MR
    Archer Fab Shop car, Showcase of the AF product line
Share this Vehicle
