- Year
- 1990
- Model/Trim
- Eagle Talon TSi AWD
- Transmission Type
- Manual
- Mods-Bolt-on
- 4G63T 6 Bolt engine Stock short block,
Big EIII16G Turbo,
Ported 2G exhaust manifold with external 38mm waste gate dumped into atmosphere,
Megan Racing full turbo back exhaust stainless steel 3",
Speed Density,
FIC 950cc injectors,
Fuel Lab FPR with -6 lines,
Fuel Lab -6 fuel filter with -6 to rail.
Walbro 255HP fuel pump with hot wire kit,
Greddy BOV vented to atmosphere,
Greddy FMIC,
NGK BPR7ES plugs,
Accell 8mm spark plug wires,
Vacuum lines removed, KoyoRad Radiator with Samco hoses,
SBR valve cover,
SBR MBC,
- Mods-Engine
- Ported head, 1mm oversize valves, manley springs, BC 272/272 cams, ARP head studs, Cometic MLS head gasket, HKS kevlar timing belt
- Mods-EMS & Logging
- ECMlink V3, AEM wideband , Ultra-Light 30# boost gauge, AEM 5 bar MAP, AEM AIT
- Mods-Drivetrain
- Dogboxracing racing trans with double syncro 2nd and welded center diff, ACT 2900# with 6 puck,XACT flywheel, SBR shift improver, Prothan mounts,
4 bolt rear, 93 Talon axles rear, Fidanza axles in front, roller bearing mod shift cables, shifter rebuilt with machined solid brass bushing.
- Mods-Handling
- 18" Exel wheel's black with red lip, 235 40 R18
- Parts Wishlist
- Automatic jackstands :p
