Please Support Kiggly Racing
tsi1991awd's Talon TSi AWD
Eagle Talon TSi AWD
-SBR Manifold
-38mm External Wastegate
-TD05-20g
-Stainless Steel O2 Housing
-3" Downpipe
-3.5" Exhaust
-3" Blitz Nur-Spec Muffler
-XSPower FMIC
-2.5" Intercooler Piping
-50mm BOV
-2g Throttlebody Elbow
-3" GM MAF
-1000cc Delphi Injectors
-255 Walbro Fuel Pump
-Fuel Pump Rewired with all 4awg Wire
-AEM AFPR
-Phenolic Intake Manifold Spacer / Gasket
-CXRacing Aluminum Radiator with Fan Shroud
-NGK Spark Plug Wires
-Non-Cruise Throttle Cable
-AVID Racing Billet Motor Mounts
Mods-Engine
-Rebuilt Head
-Rebuilt Block, 2g 8.5:1 Pistons and 1g Big Rods
-Ported and Polished Head
-Stainless Steel Valves
-3 Angle Valve Job
-3g Revised Lifters
-Cometic Headgasket
-ARP Head Studs
Mods-EMS & Logging
-3" GM MAF
-MAF-T
-Custom EPROM Chip
-SAF-C II
Mods-Drivetrain
-XTD Stage 4 Clutch with Sprung Disc
-Fidanza 8lb Aluminum Flywheel
-Stainless Steel Clutch Line
-Brass Shift Cable Bushings
-Aluminum Shift Cable Bracket Spacers / Bushings
-Symborski Shifter Base Bushings
-2g Weighted Shiftknob
-Synchromesh MTF
-EBC Drilled / Slotted Front Rotors
-EVO VII Wheels (17")
-235 / 45r / 17 Tires
-Front Upper Strut Bar
-Rear Upper Strut Bar
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
0.0 lb/ft
tsi1991awd
More in 1G DSM
Share this Vehicle
