1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
Please Support Feal Suspension
TJCTalon's Talon TSi AWD
Year:
1997
Model/Trim:
Eagle Talon TSi AWD
  • Mods-Bolt-on:
    FP 4 inch Intake, Calan Catch can set up with hal breather oil cap, Punishment racing 3inch DP Cat elem, Thermal R&D cat back, Punishment racing 38mm recurculated o2 housing, Tial F38 WG, FP HTA 71 w/TD06sl2 turbine, FP Exhaust Manifold, VRSF FMIC, 1g rebuilt Throttle Body, Evo 3 Intake Manifold, Tial BOV, Walbro 255 hp FP, Fuel lab AFPR, Halman MBC, 6AN Tank to rail fuel feed with Fuel lab Filter w/ Steel element for E85, FIC 1350 Bluemax Injectors
    Mods-Engine:
    Rebuilt head with Manley valve springs, Ti retainers, 3g revised lifters, DKS 272 cams and ARP headstuds
    Mods-EMS & Logging:
    ECMlink v3, Plug and play Speed density, AEM Wideband, prosport oil pressure gauge, glowshift boost gauge
    Mods-Drivetrain:
    XTD Stage 4 clutch (2300lb PP solid 6 puck) RRE Stock light weight flywheel 12lbs, Aluminum solid shifter cable bushings, Poly shifter base bushings, cutt+rewelded short shifter, torque solution carrier bearings, SS braided clutch line (master to slave), Poly AVID tuner solid motor mounts
    Mods-Handling:
    BC racing coilovers, OEM front Knuckle set ( new curved, and straight control arms) New tie rod ends, new front wheel bearings, Energy suspension poly bushings (rear only)
    Brakes:
    Powerslot front rotors, Hawk HPS pads all around, SS braided brake lines all around, new oem rear rotors
    17x8 FiveZigen FN10RC with Hankook RS3 245 40 17
  • 1/4 Mile E/T:
    12.400
    1/4 Mile MPH:
    142.051
    1/8 Mile E/T:
    6.214
    1/8 Mile MPH:
    111.000
    60' Time:
    1.370
    Dyno TQ:
    435.0 lb/ft
Share this Item
User Comments
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
