- Ownership Status
- Currently Own
- Year
- 1999
- Model/Trim
- Mitsubishi Eclipse GSX
- Turbo Type
- 20g
- Transmission Type
- Manual
- Build Type
- Drag Race
- Mods-Bolt-on
- K&N FIPK, 1g 60mm Throttle Body, RC 1200CC Injectors, Injen Intake Pipe, MHI 20g, EVO III Manifold Ceramic Coated/Ported, SS O2 Housing, Adjustable Cam Gears, Punishment Racing FMIC, Greddy Type-S BOV, RRE 2.5"-3" Downpipe, RRE 3" High Flow Cat, 3" Apexi N1 Catback Exhaust, Fluidyne Radiator, RRE Catch Can, 255 lph Walbro Re-Wired, Aeromotive FPR, B&M Short Shifter + Symborski Kit & Under hood Bearing/Bushings, JMFAB Intake Manifold. EVO III OFH / External Oil Cooler
- Mods-Engine
- ARP Head Studs, DKS 272 Cams, Engnbldr SS Valves & Bronze Valve Guides, EVO IX Springs & Retainers
- Mods-EMS & Logging
- Greddy Electronic Peak/Hold Boost Guage, Greddy Electronic Peak/Hold EGT, Greddy Profec-B, GM 3 Bar Map Sensor, HKS Type 0 Turbo Timer, DSMlink V3, Zeitronix WBO2
- Mods-Drivetrain
- ACT Fly Wheel, ACT 2600, RRE SS Clutch Line, Torque Solution Drive Shaft Bushings
- Mods-Handling
- Eibach Pro Kit, Tokiko Illumina Shocks, DC Sports Front Upper Strut Bar, DC Sports Rear Upper Strut Bar, Energy Motor Mount inserts, Outlander Front Caliper Brackets, Raceconcepts Drilled / Slotted Rotors, RRE SS Brake lines, RM Racing Front Sway Bar, RRE Rear Sway Bar, EVO VIII Wheels
- Parts Wishlist
- Built Trans, 6 Bolt,
- 1/4 Mile E/T
- 13.629
- 1/4 Mile MPH
- 99.970
- 1/8 Mile E/T
- 8.721
- 1/8 Mile MPH
- 80.370
- 60' Time
- 1.921
- Timeslip Video Link
- Watch Video
- Timeslip Details
- Track Name : California Speedway
Nitrous : No
Fuel Used : Pump gas
Vehicle Weight : 3200
Tires : Street Radials
Sponsored Car : no
- Dyno HP
- 296.5 whp
- Dyno TQ
- 262.0 lb/ft
- Dyno Type
- Dynapack
- Dyno Shop Name
- RRE
- Dyno Session Details
- Nitrous : No Nitrous
Turbo : Big 16G
Boost : 18
