- Year
- 1990
- Model/Trim
- Mitsubishi Eclipse GSX
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- Precision 1000cc injectors, AEM fuel rail, Walbro 255 fuel pump, AEM FPR, Buschur COP, FP intake, full 3in exhaust Magnaflow, FP exhaust mani, FP DSM86, FP 3in O2 recirc, TiAL MV-R, Hallman MBC, OEM water pump, OEM oil pump, balance shaft delete, ETS Race IC kit, Fluidyne radiator, Polyurethane motor mounts, JMF Small Battery Kit, Calan catch can
- Mods-Engine
- Stock crank balanced and polished, ACL bearings, Manley rods, Wiseco 9:1 86mm pistons, ARP Main studs, Revised lifters, BC 280 cams, BC valves, springs, retainers, bronze guides, ARP Head studs, Cometic top and bottom gasket kit, Gates kevlar timing belt, AEM cam gears
- Mods-EMS & Logging
- DSM Link V3, AEM wideband, 4 bar map, boost guage
- Mods-Drivetrain
- Stage 3 Shep Trans w/ Evo III first gear and input shaft, ACT Twin Disk
- Mods-Handling
- BC coilovers, Evo 8 Brembos
- Parts Wishlist
- DSS driveshaft, Tire Sponsorship
- Dyno TQ
- 285.3 lb/ft
