Splitpi's Eclipse GST
Mitsubishi Eclipse GST
K&N FIPK, 1g BOV, Joe P. IL Series MBC, Greddy Boost Gauge w Peak/Hold, Dejon Intake w/BOV, Megan 2.5'-3' Downpipe, 3' High flow Cat, 3' SS RNR Racing Cat Back (caution: had to be modified to actually fit) w Magnaflow #14221 Muffler, ETS Street FMIC kit, Big 16G, 560cc EVO Injectors, rebuilt and cleaned flow 780cc, but currently using stock 450's. Fuel Pump Rewire.
Mods-EMS & Logging
DSMLink, LC-1 WB, Apexi TT
Mods-Drivetrain
Amsoil 75w90 GL4 fluid
Brembo Slotted Rotors in front, EBC Green Stuff Brake Pads on all 4 rotors, 18" Exel "V-8" Rims w/ Nankang 225/40R18 tires. Tokico HP "Blue" shocks on stock springs. Front upper and lower strut braces. Rear upper strut brace. Prothane shock bushings.
Parts Wishlist
Want:
Walbro 255 LPH High Pressure fuel pump, Fuel Pressure Regulator, CFDF Clutch, Lightened Flywheel flywheel, ARP head studs ... Should put me in the 300 hp range and do it safely with a good tune.
202 hp at the wheel was on only ~9 psi of boost.
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
186.9 lb/ft
Dyno Type
DynoJet
Dyno Sheet Photo Link
Dyno Shop Name
MAPerformance
Dyno Session Details
Nitrous : No Nitrous
Fuel Used : Pump gas
Turbo : Big 16G
Boost : 9
Splitpi
More in 2G DSM
Share this Vehicle
