- Year
- 1996
- Model/Trim
- Eagle Talon TSi AWD
- Transmission Type
- Manual
- Mods-Bolt-on
- 3" cat-back /
turbo timer /
30psi/30in hg Boost Gauge /
Hard intercooler piping (short-routed) /
40mm dual-spring bov (recirculated) /
3" straight-thru downpipe /
manual boost controller (set at 20psi) /
150 ohms plug wires /
Evo III O2 housing (ported) /
Evo III exhaust manifold (ported) /
BPR7ES plugs /
190lph fuel pump (re-wired) /
Short Shifter w/ new shifter plate and underhood bushings /
FP Big28 turbo (ported, w/17psi actuator) /
28x10.5x3.5 FMIC /
SAFC II /
550cc injectors /
Custom cold air tubing /
Power Stabalizer grounding unit /
Oil catch-can /
Radiator /
57mm TB with half-shaft /
Odyssey battery /
Fuel sending SS hoses with upgraded filter /
Dual 12" slimline fans
- Mods-EMS & Logging
- Pocketlogger datalogger /
Wideband
- Mods-Drivetrain
- 2600 pressure plate & street disc /
Lightened flywheel /
- Mods-Handling
- P215/55R-16 97H XL B Pirelli P6 /
Springs (~1.4 drop) /
Front upper strut bar /
Rear upper strut bar /
Struts (front and rear, non-adjustable)
- Parts Wishlist
- 650cc injectors, 264/272 cams
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Timeslip Details
- Track Name : Knoll Gas Motorsports Park
Nitrous : No
Fuel Used : Pump gas
Vehicle Weight : 3060
Tires : Street Radials
Sponsored Car : no
- Dyno TQ
- 0.0 lb/ft
