- Ownership Status
- Currently Own
- Year
- 1997
- Model/Trim
- Mitsubishi Eclipse GSX
- Turbo Type
- GT30 Variant
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Road Course
- Mods-Bolt-on
- Bolt-on Modifications:
FMIC
2.25" IC piping
Extremepsi couplers
Tial BOV
Tial MSV 38 wastegate
Evo III Intake Manifold
1G NT throttle body
FP Race exhaust manifold
HX35 w/BEP bolt-on turbine housing
Punishment Racing 02 housing converted to v-band
3" SS downpipe
3" SRS R1 SS exhaust
Bosch 2000cc injectors
Aeromotive fuel rail
Aeromotive AFPR w/ gauge
Race Parts Solutions in-line SS fuel filter
SS fuel lines
Walboro 450 E85 pump
Buschur COP with Dynatec ignition box
Fidanza cam gears
FP 4" intake
Forward facing oil filter housing
Crushed water pipe
Mishimoto x-line radiator
Mishimoto coolant temp sensor adapter
Mishimoto 25 Row Oil cooler
Mishimoto coolant reservoir
Mishimoto Radiator cap
Moroso oil pan
Moroso cut off switch
Moroso battery terminals
Taylor battery box.
FTP 4an vacuum line set up
FTP 10an catch can lines
FTP 12an oil drain line
Driven 12.9" steering wheel
Driven quick release,
Driven Halo racing seats
Sparco hub adapter
Sparco steel side mounts
Carbonetics AB hood
Carbonetics rear diffuser
Carbonetics dash - on order
Carbonetics door panels - on order
Aerocatch 120-2100 hood pins with upgraded steel rods
- Mods-Engine
- Engine Internals:
6-bolt block .020 over
ARP classic head studs
Wiseco 9:0 pistons
Eagle H beam rods
ARP main studs
BSE
Kiggly crank trigger
Kiggly HLA pressure regulator
Fel-Pro HD MLS headgasket
HKS 272 cams
Crower valve springs
Crower Titanium retainers
Ferrea valve seals
DEI wrapped downpipe with silicone
DEI cool tape intake
DEI cool tape lower I/C pipe
DEI cool tape water pipe
DEI cool pad oil pan
Extremepsi phenolic intake gasket.
- Mods-EMS & Logging
- Ecmlink V3 on speed density
AEM digital boost
AEM digital oil pressure
AEM digital oil temp
AEM digital coolant temp
AEM digital wideband
AEM digital Fuel pressure gauge
Ortiz Hvac triple dash pod
Ortiz Dual center vent pod
Ortiz Dual instrument cluster pod
- Mods-Drivetrain
- Drivetrain Modifications:
Stock 5-speed tranny,
SS clutch line
ACT 2600 PP & 6-puck disk
12-lb chromoly flywheel
Stock Rear LSD
Prothane mount inserts
Solid shifter cable bushings
Torque Solutions Drive Shaft Bushings
Torque solutions 12mm exhaust hangars
Fluidampr crank pully
ARP crank pulley bolts
Boston Hatcher rear diff bushings
Split motorsports rear aluminum subframe bushings.
- Mods-Handling
- Suspension Modifications:
Design RP5's 18x8, 235/40/18(street)
Evo x 18x8 - 245 tires
G-loc R16 front brake pads(track only)
G-loc R10 rear brake pads(track only)
Evo 9 brakes all arouns.
SS brake lines
Non ABS setup
Depowered steering rack
Drilled and slotted rotors(street)
Blank rotors (track)
FEAL 441 road race coil overs
Paul Volk Front LCA
Paul Volk Rear Toe Arms
Bobby's adjustable rear wishbone
Bobby's bump steer kit
Bobby's rear lower lateral arms
Bobby's trailing arms.
Bobby's front upper wish bone
Mishimoto locking wheel nuts
Porsche brake ducts
Comp works fender braces.
RM Sway Bars
DC sports 1001 front strut bar.
Polybushing everywhere there isn't spherical currently
Full cage.
- Parts Wishlist
- Enkie rpf1 18x10.5 +15
Carbonetics fender flares
Carbonetics front lip
Carbonetics side skirts
Bobby G - Modified big tire knuckles
G-Force FIA harnesses
Race capture pro, complete J. Freund setup
TPMS system
Gopro
