- Year
- 1992
- Model/Trim
- Eagle Talon TSi AWD
- Transmission Type
- Manual
- Mods-Bolt-on
- 4g63 bored .40 over, ARP head studs, ballance shaft elim kit, Wiesco >.040 over 8.8:1 pistons, Kiggley 6 bolt girdle, Eagle 4340 6 bolt 2.3 stroker crank, ACL bearings, Mitsu 4 layer H gasket, STG 3 port n polish from Harrys Heads, fearra SS valves 3 angle 4 angle,0100 series crower valvle springs and titanium retainers and locks, running GSC STG 2 274/274 duration cams, BBK 75 mm trottle body with TPS, 75mm magnus sheet metal intake man stock fuel rail, Walbro 255lph, rewire kit, polly motor mounts, fidanza short throw, ETS 3.5 intercooler short route, Forced Performance HTA 68. DSM link V3 lite, AEM wideband, 1250 FIC injectors, Fuel Lab FPR, all briaided SS line, NGK plugs, magnacore 8mm wires. CX racing aluminum radiator, Samco sport hoses, Punsishment racing SS downpipe, FULL 3 in S
- Mods-Engine
- My favorite subject.
block. bored .040 over, line bored, and lower balance shaft removed. wiesco.040 over stoker pistons, SCAT rods, with a 4340 Eagle 100mm 6 bolt stroker crank, block 45-60 RA for MLS
the head is my pride and joy
stage 3 head, port and polish, bronze valve guides, new valve seals, ss fearra valves 1mm overbore, 3/4 angle valve job, crower 0100 springs, titanium crower retainers,. New hydrolic lifters, w new rollers, GSC stage 2 cams, aem true time cam gears, ARP everything, head studs, rod bolts, cam lock bolts, even valve cover bolts. Gates racing timing belt, balance shaft eliminator kit, and repositioning of the coil pack. Front facing oil filter bracket.
- Mods-EMS & Logging
- DSM link V3 lite, AEM wideband, Cobalt boost gauge, cobalt oil press gauge, cobalt water temp, cobalt EGT gauge
- Mods-Drivetrain
- 2600lb ACT 6 puck unsprung clutch. NEW OE clutch fork, TOB, braided steel master to slave cylinder line.
- Mods-Handling
- KYB AGX2 front and rear. Eibach lowering springs, upper front and rear strut tower braces. Perelli P zeros
2G front dual piston calipers mod. REAL Brembo slotted rotors front and rear. wilwood braided steel clear plastic insulated brake lines all around.
- Parts Wishlist
- Jacks Trans 2.2 HD. A ton more too much to list
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Timeslip Details
- Fuel Used : Pump gas
Tires : Street Radials
- Dyno TQ
- 0.0 lb/ft
