- Ownership Status
- Currently Own
- Year
- 1995
- Model/Trim
- Eagle Talon TSi AWD
- Turbo Type
- GT35 Variant
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- If you want to see all the pics of the build so far, mixed in with other random distractions:
http://s1376.photobucket.com/user/Shawn_Wild_M_Antonia/library/
UPDATE: Took it to English Racing & put down a respectable 635AWHP on their Dyno:
https://youtu.be/0GKLRT_hcQE
I'VE RAN INTO PROBLEMS WITH A BAD COIL ON PLUG on my Sparktech (Caused cyl. wash-down & almost destroyed my engine & my bearings got chewed up a bit),
-Aeromotive sent out a bad batch of FPR SPRINGS! Had to wait awhile, but finally got that replaced), then ran into fuel pump pickup leaking from the weld(Need to put a bulk-head fitting in it, or buy FullBlown Racing's setup), I took a new job, haven't had time to mess with it, and a bunch of other misc. issues. ALSO, I HAD FURTHER HEALTH ISSUES(retinal hole in my right eye from Iraq that has gone unnoticed all these years that I need to have surgery on)& THE PROJECT IS ON HOLD UNTIL I REBOUND FROM LIFE'S AWESOME SUCKER PUNCHES.
LOOK FORWARD TO COMPLETING IT & RACING IT.
CONSTRUCTIVE CRITICISM IS APPRECIATED.
***(FUEL):
-Walbro 450 E85 compliant in tank,
-Bosch 044 rewired inline,
-FIC 2150cc Hi-Z injectors,
-Fuel Lab fuel filter with check valve
-8AN feed
-6AN Return
******(MISC):
ACL Race Bearings
Dual Tial 44mm Wastegate with 14.7psi springs
Viton valve seals
-10AN catch can lines
-Gates Racing (300% stronger timing belt)
-Fidanza adjustable cam gears
-Zaklee clear timing belt cover
-Jay Racing alternator relocation kit(Alternator mounted on back of engine)
-Transistor delete
-Balance shaft elimination kit
-A1 technologies head studs
-S90 70mm throttle body
-Magnus intake manifold spacer(made of high temp composite plastic. Prevents heat transfer from engine to intake. manifold)
-B&M oil cooler
-B&M short shifter
-Redline fluids throughout whole car(Trans, rear diff, transfer case)
-LOAD BOSS 160amp alternator
-custom Hyundai valve cover(shaved) & plumbed for -10AN fittings for catch can
-blueprinted & balanced whole rotating assembly with Quartermaster twin-disc clutch on it.
-welded up & shaved whole engine bay(deleted firewall insulation, any pinch weld marks, reinforced & welded engine mounts brackets.
-97-99' front end conversion
- VIS carbon fiber hood(slightly cracked, been repaired).
-deleted rear seat/interior pieces
-put in lightweight manual seats
-deleted a bunch of airbag, ABS stuff, crash sensors
Prob. left out some things even with that long list.
***(SAFETY):
-5 point harness
-4 point cage,
-batt. Cutoff switch
-window net
-fire extinguisher
-Scattershield
-Drive-shaft loop
-Most everything heat wrapped, or insulated from heat.
- Mods-Engine
- -deleted A/C, EGR, Cruise, P.Steering
-MOROSO oil pan (-10AN oil return)
PTE6262 turbo with T4 housing, billet wheel, and .58A/R
JMF T4 topmount exh. Mani,
custom 3" V-band exhaust(Turbo back) no cat, just muffler at back
, Kelford 280 cams,
Wiesco 1400HD 8:5:1 pistons,
Ferrera S.S. valves w/3 angle & back-cut,
maganese valve guides,
Kiggly HLA pressure regulator,
kiggly main brace
ported 6 bolt head,
-MAP Howard rods(good for 1,000HP)
Kiggly beehived valve springs(Titanium keepers & retainers) good to 11, 000RPMs,
Ported 90' OFH,
Tial recirc. BOV,
cusom 2.5" IC piping done by me,
Mishimoto 3 row radiator,
6 bolt block,
Fluidampr crank pulley,
-poly engine mounts all around.
- Mods-EMS & Logging
- Currently running on ECMlink V3 with *speed density
***(I also have an AEM EMS Series 1)
-Kiggly crank position sensor
-black top CAS
boost, oil, wideband, water, cobalt gauges,
- Mods-Drivetrain
- Shep. Stage 4 trans(ISF process) welded center diff.
scattershield,
Quartermaster Twin-disc clutch,
- Mods-Handling
- -Nitto 555 street slicks on Rotas
-Megan 32 way adj. Coilovers,
- Ingalls +- 1.5 adjustable camber plates, (front & rear)
-poly suspension inserts & drive-shaft
- Parts Wishlist
- -Built transfer case
-AEM Series 2 (OR......SINCE THIS IS A WISH LIST! A FULL ON MOTEC SYSTEM!) Haha.
-GT35R
-Auto Trans
-Built axles
-One piece drive-shaft
-Rear subframe from MAGNUS RACING
-Racing seats
-Racing steering wheel
-Lighter wheels & tires.
-Dry sump -MAGNUS
-2.3L MAGNUS built engine
-BrakeMan brakes
-Parachute
-Expand on rollcage
-Carbon Fiber doors, hood, trunk
-FULL BLOWN's fuel pickup assembly
-Nitrous
-CRYO sprayer
-Better seat belt harness
-Stereo
-Get rid of glass & replace with LEXAN
-Different paint job(something unique & mean)
-Exhaust cut out(Doug's headers)
-Swain or Calico-coated engine internals & transmission & rear diff. internals also.
-Helmet
-Haun's device
-Fire retardent racing suit(gloves, head sock, shoes, socks, etc).
-MIL. SPEC wiring harness.
-Magnus Intake mani.
-Top of the line SPARKTECH Ignition system
-Custom exhaust routed out the hood
-Launch control device if I am to stay manual(for perfect launches each time) MAGNUS
-OK, PRETTY MUCH EVERY DAMN PART MADE BY MAGNUS!
**********************Does the wish list ever really end?
- Background
- Through numerous health issues after serving in Iraq, buying a house, learning the hard away about cheap parts(when you're new to modding cars you do lots of dumb stuff), shady performance shops, thieves, distractions(started messing with Euro cars, motorcycles, Diesel trucks, chasing women, partying too much, traveling, breaking up with girl, going to school, taking a new job, etc.....you guys understand LIFE HAPPENS).
Just wanted to inspire other people to have fun in this hobby, work hard, and do what you're passionate about. Also, help other people out if they decide to shave their engine bay.
I did most of the work myself & with a few good friends helping me out. This is my first attempt at building a wannabe race car, 6yrs in the making, learning how to weld, body work, paint, wiring, soldering, custom fab., compiling your wish list & then getting realistic, redoing stuff, rethinking your build, waiting a few yrs. & then better parts come out, you name it! I appreciate any constructive criticism, as I still need to finish it(axles, seats, drive shaft, lighter wheels & tires, some wiring, fuel, tuning, & work out a bunch of other kinks).
