- Year
- 1998
- Model/Trim
- Mitsubishi Eclipse GSX
- Transmission Type
- Manual
- Mods-Bolt-on
- Forced Performance FP3052 - RC 1000cc injectors -3" Thermal exhaust - 3" Espilir downpipe - Fluidampr crank pulley - Walbro 255lph fuel pump - SX fuel pressure regulator - Earl's oil cooler - TiAL blow off valve - TiAL 44mm wastegate - Garrett intercooler - K&N air filter - JMFab catch can - 3" GM MAF and translator - Fluidyne aluminum radiator - SPAL radiator fans - VIS carbon Fiber hood - Sparco hood pins - Magnacore spark plug wires - Injen spark plug cover - Venom intake manifold - 60mm throttle body.
- Mods-Engine
- 1G head - FP2x cams - FP/Supertech dual valve springs - FP/Supertech titanium retainers - SI nitrided 1mm oversized valves - Mitsubishi four layer metal headgasket - ARP head studs - factory 6 bolt bottom end - Power Enterprise kevlar timing belt - Unorthadox Racing cam gears
- Mods-EMS & Logging
- DSMLink - hallman boost controller - Innovate wideband O2 - Autometer Ultralite boost and oil pressure gauges
- Mods-Drivetrain
- AWD conversion - ACT 2600 clutch - Fidanza flywheel - NON-LSD rear end - Greddy shift knob -Symborski shift kit - B&M shifter assembly
- Mods-Handling
- Rotora BBK front - Rotora rotors rear - Rotora SS lines all around - Tein basic w/ upper pillowball mount - SPC Upper control arms (front) - RRE camber kit (rear) - 5-Zigen 17x9 FN01R-C +35 - 255/45/17 BFGoodrich G-Force Sport - factory swaybars
- Parts Wishlist
- Swaybars - new pads - money for track day - tires...
- 1/4 Mile E/T
- 14.520
- 1/4 Mile MPH
- 99.170
- 1/8 Mile E/T
- 9.582
- 1/8 Mile MPH
- 75.989
- 60' Time
- 2.379
- Timeslip Details
- Track Name : Sacramento Raceway
Nitrous : No
Fuel Used : Pump gas
Tires : Street Radials
Sponsored Car : no
- Dyno TQ
- 0.0 lb/ft
