Please Support Rix Racing
Street Build rscott's Eclipse GSX
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Turbo Type
16g
Build Type
  1. Street
FP 68HTA 16G (style) turbo w/ wastegate
Pierburg Boost Controller
WALBR0 255 fuel pump
Mishimoto Radiator w/ Mishimoto piping
Fans (stock both w/ custom heat sheilding on hightemp fan)
ETS FMIC 7"height 3width" 23Lendth" (kit)
ETS Piping w/ some customer adjustments
Synapse Blowoff valve
FP DSM Race Manifold
STM DSM Recirculated O2 Housing
Buschur Racing 2G 3" AWD Mandrel Bent Downpipe
Vagrant?? 3" High flow cat
Thermal research 3" catback cut & weld to make full 3"
Injen Ram Air Intake and blue filter
Coolness:
GROM-BT3 - input aux3.5/bluetooth in arm console (cd trunk replacement,
requires a trick switch on/off for stock radio handshake)
Racing 3" Air flow from bumper side vents (RED) into engine bay / air intake
Mods-Engine
2G Block 7bolt (stock)
GSCR2 Cams
ID1000 Injectors
NGK wires
BPR8EIX plugs
ARP Studs
Mods-EMS & Logging
ECU ECMLink 3 (a.k.a dsmlink3)
Dual Pod gauge console
Dual PLX Device guages + PLX Boost, PLX Wideband AFR sensors
Mods-Drivetrain
STG 3 competition clutch
Drivetrain (stock) w/ DIAQUEEN LSD fluid
Tansmission stock w/REDLINE (MTL) & REDLINE (MT90) mix
DG Setup racing coilovers with Koni Yellows (lowered approx 2 inches)
Ingalls (avenger) rear camber adjusters
Enkei PF01 18x8 rims TireRack (5-114 ET/Offset 40)
Goodyear 235/40R18 Eagle GT XL
Parts Wishlist
Brakes (TBD)
Background
DSM Freak!!, Fell in love with my 1990 GST and moved on to my 1997 GSX .
Purchased my GSX in 1997 brand new with 7 miles on it. It's been rock solid, never had a problem. In past 4 years I've made the move to stage 1 and now to stage 2. With my last set of mods the car has changed dramatically.. really it is a racecar. It's a daily driver (good weather), I've kept is stockish looking but it sounds wicked and turns into instant beast nightmare!
Dyno Tuned: 362whp (approx: 400-420bhp)
Couldn't of done it without guys at Moore's Automotive (Fairfax, Va) (They know their Shit)
1/8 Mile E/T
1.234
1/8 Mile MPH
12.345
Dyno HP
414.2 whp
385.2 lb/ft
Dyno Type
DynoJet
  • Like
Reactions: d1prospect
rscott
Rating
4.67 star(s) 3 ratings
More in 2G DSM
Share this Vehicle
