Street Build RocCitySlayer's Eclipse GSX
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Build Type
  1. Street
2g Fmic with short route intake pipe, 7 Blade Holset Hx35 turbo with bep hotside .55ar housing internally gated, MBC, Recirculated HKS SSQV Blow Off Valve, Forced Performance race manifold, 1g Head ported on a 2g 7bolt, 1g TB, 1g CAS, 1g Intake manifold, 2g Maf, FIC 1050cc Injectors with Fic seals, High Flow Aem Fuel Rail, 4" recirculated FP Air Intake with 4 1/2 in K&N filter For Turbo, Eccell wires (8.5mm) and NGK Bpr8es plugs (Gapped to .28), 2g Non-cruise throttle cable, 3in Downpipe back Apexi exhaust, Tsuedo muffler
Mods-Engine
Crower Springs and Titanium retainers, Super tech swirl polished nitride coated exhaust valves, REV SS swirl polished back-cut intake valves, Bronze valve guides, Super tech valve seals, HKS 272 (E) 264 (I) Cams, Oem Timing Belt, Oem rockers, 3g Revised Lifters, Balance shaft eliminated, Eagle rods and Eagle pistons, Balanced crank shaft
Mods-EMS & Logging
Dsmlink V3, Walbro 255 fuel Pump, Aero a1000 fuel pressure regulator (43.5), Glowshift tinted Vac gauge, Glowshift tinted Boost Gauge, Aem Uego Wideband (Considering Mtx-l)
Mods-Drivetrain
Stage 3 Shep 5 Speed Tranny with short throw, Act 2600 clutch kit, Act Pressure Plate, 6 Puck Street Disc, Fidanza Flywheel
Tein fully Adj coilovers, 19in Racing Hart C2 Evo Wheels, General Exclaim Zr Rated tires 235/35/19, 2g Chamber kit
Parts Wishlist
External wastegate SS 02 setup, T3 .70ar housing and a few other things, 17in Drag radials (street legal)
Timeslip Details
Nitrous : No
Fuel Used : Pump gas
Tires : Street Radials
Sponsored Car : no
Dyno HP
350 whp
300 lb/ft
Dyno Type
Mustang Dyno
Dyno Shop Name
STM
Dyno Session Details
Nitrous : No Nitrous
Turbo : Hx35
Boost : 24
  • Like
Reactions: speedpro22
RocCitySlayer
More in 2G DSM
Share this Vehicle
