- Year
- 1993
- Model/Trim
- Eagle Talon TSi AWD
- Transmission Type
- Manual
- Mods-Bolt-on
- Custom 3" straight exhaust. JMF custom T3 Exhaust Manifold, 44mm Tial Wastegate w/ atmospheric dump tube, JMF Drag intake manifold, 75mm Boomba Throttle Body. -8 inlet -6 return black stainless steel fuel lines. Holset HX-40pro 6blade BEP .70 A/R turbine housing. Battery relocation to rear. polyurethane solid motor/trans mounts, Jay racing alternator relocation kit, powder coated valve cover and coolant pipe. custom oil dipstick lock :)
- Mods-Engine
- .020 over fresh 2.0 block, 8.3:1 Wiseco Pistons, 5900MBA Steel H Beam Eagle Rods, ACL bearings, OEM gaskets, Mitsu Multi Layer Head Gasket, ARP head studs, Manley springs, HKS 272 int/exh, port gasket matched/polished cylinder head, Greddy Timing Belt, BLESolid Timing Belt Tensioner, New timing components, forward facing Oil filter housing.
- Mods-EMS & Logging
- AEM V2, speed density set up GM IAT sensor, AEM 3.5 bar MAP sensor. boost, oil, coolant temp gauge, egt gauge, AEM tru boost wideband
- Mods-Drivetrain
- 2900 ACT Pressure Plate, 6 puck sprung ACT clutch, ACT lightened flywheel, extended slave cylinder rod. solid drive shaft bushings,
- Mods-Handling
- 16" rims.
- Parts Wishlist
- John Shepherd stage 3 transmission and drivetrain. spark tech COP set up. DSS axles and driveshaft, suspension upgrade
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Timeslip Details
- Nitrous : No
Fuel Used : Pump gas
Sponsored Car : no
- Dyno TQ
- 351.5 lb/ft
- Dyno Type
- DynoJet
- Dyno Shop Name
- DIA auto @ virginia beach
- Dyno Session Details
- Nitrous : No Nitrous
Turbo : Holset hx40
Boost : 26
