- Ownership Status
- Currently Own
- Year
- 1992
- Model/Trim
- Eagle Talon TSi AWD
- Transmission Type
- Automatic
- Build Type
- Drag Race
- Mods-Bolt-on
- T4 BEPS366, DNP T4 Mani, TurboSmart 45mm External, full 3 inch turbo back, FRH Intake manifold, Fidanza adjustable cam gears, Crane Fireball HI-62 CDI, TIAL BOV, ETS Race FMIC 3.5", Nitrous 50 shot dry kit, In tank Walbro 450, Inline Bosch 044, -6 fuel line tank to rail, Aeromotive AFPR, FIC BlueMax 2150cc injectors, relocated battery to the trunk in a Moroso battery box, etc etc..
- Mods-Engine
- .020 over 6 bolt, wiseco 9.0:1 pistons, eagle h-beams, stock std size crank, clevite engine bearings, oem oil pump with polished straight-cut gears. Stock head with a mix of ebay 'engbldr' & SI stainless valves, manley springs w/crower titanium retainers, kelford 272 cams, MAP H11 studs with an ebay Nippon MLS gasket.
- Mods-EMS & Logging
- ECMLink V3, omni power 4 bar map sensor, Innovate MTX wideband
- Mods-Drivetrain
- Auto swapped awd 5 speed car, IPT end clutches, Kiggly front clutch pack, Kiggly Flexplate, welded center diff, Translab HP shift kit, bradco "tight" converter, manumatic mode with a fourcedfour.com shift box basic.
- Mods-Handling
- KYB AGX's with ground control sleeves
- Parts Wishlist
- 10pt roll cage, new set of M&H Racemasters, too much to list... Not enough money..
- Background
- This is my 3rd DSM over the past 12 or 13 years. I've been getting dumber and dumber with these cars lol. I do all my own work, mainly because I like to do things myself and partly because I'm a cheap ass - like most DSM owners. Plan on getting this thing well into the 9's at some point, but I don't have as much time to mess with it as I used to. The car has been running with this setup for over a year and I haven't even taken it to the track...
- 1/4 Mile E/T
- 10.67
- 1/4 Mile MPH
- 126.86
- 1/8 Mile E/T
- 6.76
- 1/8 Mile MPH
- 100.7
- 60' Time
- 1.57
- Timeslip Details
- Nitrous for stalling up, E85, 28-29psi of boost.
Videos
10.6 @ 126.86mph - Stock 6 bolt bottom end
6.8 @ 108mph ini the 1/8th mile - Stock 6 bolt bottom end
Stock 6 bolt destruction
Was a great shortblock, paid 100 bucks for it and I don't even know how many 10 second passes it made . Plus a bunch of 6.90's in the 1/8th. I died a an honorable death.
1992 Talon 13.7 @ 100
10-31-09
Second time at the track ever. 16g running 18-19psi of boost tuned by me with a SAFC.
1992 Talon 13.2 @ 104.9 mph
Running a 13.2 @ 104 on December 5, 2009. 16g @ 21 psi falling to 19-18 at redline.
Mustang vs Eagle Talon (1g DSM)
Running my car at Irwindale 1/8 mile dragstrip, 7.47 @ 97mph. First time out on the HX35. Got lined up against this unsuspecting mustang Still needs a better tune but it's going good so far.
1G DSM vs Mustang 5.0 - 11.6 @ 125mph
Twilight Drags in September at the Autoclub Dragway in Fontana, CA.
Eagle Talon TSI 12.5 @ 118mph
My 1992 Talon drag racing at the Autoclub dragway in Fontana, CA. 7-17-2010. This was the first (and worst) run of the day. I bogged the launch pretty bad and it was over 100 degrees on the track. I ended up running an 11.8@120 and 11.9@122mph later in the day.
1G auto HX35 in car
Running low 11's about a year ago in my auto swapped 1G. No nitrous for the launch as I was having issues with it on the line but I did spray it (50 shot) at the top of 2nd gear, let off for the shift and sprayed through 3rd gear. At the time, this motor's best cylinder was 130ish psi of compression.
John Shepherd skating down the track at E-Town
Old video I couldn't find online anymore. So I decided to upload it to youtube.
10-31-09
1G auto HX35 in car
