- Year
- 1991
- Model/Trim
- Mitsubishi Galant VR-4
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Engine
- Engine:
.020 bored block
full blue printed
wiseco pistons
ARP head studs, Main bolts and connecting rod hardware
Eagle H-beam rods
BSE kit
All new gaskets (FelPro)
New water pump and timing components (Gates)
Gates Racing accessory belts
Gates Racing timing and balance shaft belts
Zaklee clear timing cover
Fluidampr crankshaft damper
90' oil cooler setup
Avid solid aluminum motor mounts
Black top CAS
NGK BPR6ES plugs
NGK Wires
Rebuilt Head
HKS 264/272 Cams
AEM Truetime adjustable cam gears
- Mods-EMS & Logging
- Tuning:
ECMlink V3 full
Innovate LC-1 Wideband w/ integrated auto timer & voltage gauge
Stewart Warner Gauges (boost, fuel press, oil press, oil temp, voltage)
- Mods-Drivetrain
- Drivetrain:
Stock manual 5 speed trans and transfer case
Redline fluids
Clutch pedal rebuild
ACT 2600 clutch
Lightened flywheel
ARP flywheel bolts
Stainless clutch line
New OEM clutch slave
- Mods-Handling
- Brakes/Suspension:
ABS delete
4WS still intact
KYB AGX adjustable Struts (4 way front /8 way rear)
B&G lowering springs
Whiteline front 22mm swaybar
Front and rear strut bars
5 lug Swap
Slotted rotors front and rear
All new lug nuts
Enkei Evo 8 wheels
- Parts Wishlist
- FP dsm flange headers, SMIM, New tranny, new 1 piece drive shaft and many other parts.
- Background
- From the ashes of death will bring new life.
