Please Support JNZ Tuning
Please Support Rix Racing
psychbiker1966's Eclipse GSX
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Turbo Type
GT35 Variant
Drivetrain
AWD
Build Type
  1. Road Course
FP 3794 RED Jack T3 exhaust manifold. FP External wastegate, 3 inch downpipe, Thermal R&D exhaust, JMF Race
Intake mainfold, Intake and K&N filter, Custom crankcase ventilation set up and catch can, Precision IC core, Custom Intercooler piping, Tial BOV, Dual Walbro 450 FIC 2150 cc injectors.Fuel lab FPR, Gates Racing performance coolant hoses,Fluidyne radiator,EvoIII external oil cooler filter mount, Setrab oil cooler set up,Setrab power steering cooling setup. Chaser Carbon Fiber vented hood, Prothane Motor mount kit.
Mods-Engine
FIST Stage 3 1G head port and polished,1mm oversized valves,FP High Pressure Beehive Spring Set, FP 4R Cams,FP Adjustable cam gear,Updated 3mm lifters, Kiggly HLA Pressure Regulator, 2.0 Short Block (6 bolt), Weisco 8.8:1 pistons , manley rods, ACL Tri- Metal Race bearings, True 4G63 crank, BSE kit< Fluidampr Harmonic Damper,Cometic HG,ARP head studs.
Mods-EMS & Logging
DSM Link V3 w/speed density & boost control solenoid. PLX SM -AFR wideband.
Mods-Drivetrain
matched and balanced ACT 2600 and ACT Streetlite Flywheel matching by jacks Transmissions, Shepard 4 spider center diff, SS clutch line, Symborski shifter kit and Mach V cable bushings, Jacks custom road race spec transmission, Jacks T-Case rebuild.
SPC Front upper control arms, Muellerized JIC Coilovers, Energy Suspension front conrtol arm bushing kit, RM sway bars,JDM Galant Knuckles, EVOIII Breambo calipers,front & rear, SS brake lines, RRE Stock brake rotors, Carbotech XP-12 fronts, Hawk HP+ rears, Kosei K1-TS 17x9-35, Enkei EVO VIII 17x8-38, 4PT Autopower roll bar.
Parts Wishlist
PPG Gearset. Air conditioning... Working passenger door handle.. HID bulbs... alternator relocation.
Background
This car "Skye" had its own facebook page. (not kidding) It was a road racing DSM built and sponsored by FIST racing in Houston and raced by Kevin Tan. I have owned her since 2013 and now she has only seen street duties. I would like to up my boost to 32-35 lbs for 600+ whp but my transmission seems to have other ideas!
1/8 Mile E/T
8.0
1/8 Mile MPH
100
Dyno HP
480 whp
345 lb/ft
Dyno Type
DynoJet
Dyno Video Link
Watch Video
Dyno Shop Name
CP Motorsports
Dyno Session Details
Nitrous : No Nitrous
Fuel Used : E85
Videos
  • Like
Reactions: AllenTallen
psychbiker1966
Comments
More in 2G DSM
Share this Vehicle
