Please Support Rix Racing
projekt1's Talon TSi AWD
Ownership Status
Currently Own
Eagle Talon TSi AWD
Turbo Type
16g
Drivetrain
AWD
Build Type
  1. Street
B16g: EvoIII o2 Housing: FP Race Manifold: 1G BOV (Crushed): SBR Short Route FMIC: Megan Racing Exhaust (turboback): Walbro 255LPH Fuel Pump (Hard/Rewired): FueLab FPR (BFP 42.6psi): FP Intake w/K&N Fiter: Koyo Rad: NGK Plugs/Wires:
Mods-Engine
Rebuilt/Stock bottom (2g pistons-1g rods): Bian Crower 272 Cams: Crower Springs/ TI Retainers: Revised 3G Lifters: UO Crank, Alternator and Water Pump Pulleys + Adjustable Cam Gears: Complete ARP Hardware: BSEK Done: Gates Racing Performance Timing Balance Belts + Coolant Hoses:
Mods-EMS & Logging
ECM Link V3 w/SD harness, GM IAT: Innovative MTX-L WB: GM 3Bar MAP
Mods-Drivetrain
91' TRE Stage 2.1 Tranny w/4-spider diff: Act 2600 w/Street disc: ACT Flywheel: Symborski Shifter Kit: 91' Shifter base + cables: 4-Bolt Rear w/LSD Swap
Megan Racing Coilovers: Font/Rear Upper Struts: Ingalls rear camber arms: RM Rear Swaybar: Manual Rack Swap: 2G Dual Piston Caliper's w/Redstuff Pads: SS Brake lines
Parts Wishlist
E-85, E-85, E-85, Bigger better turbo?, ? 1200cc+ Injectors?, Stroker rebuild?........
266.2 lb/ft
Dyno Type
DynoJet
Dyno Sheet Photo Link
Dyno Shop Name
Lucas/ English Racing @ Wyotech
Dyno Session Details
Nitrous : No Nitrous
Fuel Used : Pump gas
Turbo : Full Garrett
projekt1
More in 1G DSM
Share this Vehicle
