Project Zero Day - 2g Holset GST (AWD Swapped)
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Drivetrain
AWD
Build Type
  1. Drag Race
7blade Hx40 w/FP-T31 housing (.68 a/r) w/Tial 44mm external wastegate (dumped)
FP vband o2 housing
FP race manifold
FP Intake (no maf)
Walbro 450lph pump (rewired)
6an tank-to-rail braided nylon w/SS Russell filter
FIC 2150cc injectors
Fuel Lab afpr
VRSF intercooler w/greddy type-s BOV (vented)
STM 3" Exhaust
w/BR7ES plugs
Prothane motor mounts
EGR/vac delete
Mods-Engine
Felpro headgasket
ARP head studs
BC 272 Cams
BC valve springs
Rear balance shaft delete
Gates timing belt
Grade 1 Motor Oil (BPO-009-7150)
WIX Oil Filter (51381)
Mods-EMS & Logging
e85
ECMLink v3 full w/speed density, NLTS, and boost-by-gear :)
Tuned by c2ypt1c
Ingersoll boost control solenoid
Innovate LC-1 Wideband (@FrontO2)
Omnipower 4-bar MAP
GM IAT
Gauges: boost, afr, and oil psi (turbo feed)
Mods-Drivetrain
AWD Swapped
SouthBend SS-X w/full ceramic unsprung disc
ss clutch line
Extremepsi brass bushings
Motul Gear 300 Oil (MTL-100118)
RedLine 80w140
Ground-control coilovers (600F/1000R) /w upper mounts
Koni yellow shocks
Volk Racing front lower control arms
Dyno HP
524.5 whp
Dyno Type
Mustang Dyno
Dyno Video Link
Watch Video
Dyno Shop Name
Import Auto Pros, CA
Dyno Session Details
29psi
  • Like
Reactions: bigdnno98
c2ypt1c
Comments
2
More in 2G DSM
More from c2ypt1c
Share this Vehicle
