pagosa dsm's Talon TSi AWD
Eagle Talon TSi AWD
Build Type
  1. Street
190 fuel pump,rewire fuel pump,fmic,1990 oil cooler and housing,custom upper,lower2 1/2 icp,egt gauge boost gauge,mbc ,550inj, 2nd gen maf ,safc ,logger, holset hx35,setrab p/s cooler, kn air filter, symborski kit, shifter bushing,rod ends on shifter cable at shifter,shifter bronze bushings,turbochargers .com oil feed line,battery moved to the right rear of car, center force, Tial waste gate, clutch,SS fuel line from the filter, aluminum radiator,S S clutch hose,carrier bearing aluminum bushing, 3000gt shifter
Mods-Engine
2nd gn ported manifold, custom made o2 housing /wTial ex.wastegate, 2 1/2 turbo back exhaust, , new engine,cometic head gasket,HKS 272 cams
Mods-EMS & Logging
Innovate wide band
Mods-Drivetrain
tubular rear diff support, evo 9 diff
cobra front caliper,12" crown vic rotors,96 custom rear corvette caliper and 12" rotors with hand brake,SS brake hoses,Evo 17" rims,235x45x17" tires,Bilstein HD strut inserts, adjusted bump steer with rod ends tie rods, rod end rear suspension arm, adjustable tubular upper control arm with rod ends,suspension techniques 1" rear ,sway bar,custom 3 point front ,rear strut bars,front rod ends swaybar links,custom rear sway bar links with rod ends at both ends,, ray peters rear sub frame bushings,ground control camber,caster plates,ground control coil overs375 front 250 rear springs,corner weighted, custom rear lower tubular control arms ,front lower steel control arm bushings,custom high presure and low presure S.S. P/S lines,front -1.7camber,+ 5 caster,0 toe,rear -1 camber 0 toe, 3rd gen master cylinder and brake booster
Parts Wishlist
last thing new paint,,Speedway motors rear sway bar,
1/8 Mile E/T
7.431
1/8 Mile MPH
94.150
  • Like
Reactions: TheRippedNerd
pagosa dsm
More in 1G DSM
Share this Vehicle
