- Ownership Status
- No Longer Own
- Year
- 1990
- Model/Trim
- Eagle Talon TSi AWD
- Turbo Type
- 16g
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- E316g. Fp manifold. Front mount. 3 inch exhaust. 255 fuel pump rewired. 650 injectors. Gm maf.
- Mods-Engine
- Stock.
- Mods-EMS & Logging
- Ecmlink v3
- Mods-Drivetrain
- Stock.
- Mods-Handling
- Stock.
- Parts Wishlist
- Meth injection. Coilovers. 235/17. Harness bar.
- Background
- Always liked dsm when I was younger so when I decided I wanted a project car I knew what it was going to be. So set out for a 1ga knowing only that I wanted the one with pop up headlight lol.
Found good looking clean one with most of the mods already done but the car need some love. I picked it up at a fair price and set out to fix it up and make it a fast spooling street machine.
Fast forward to summer 2016 the car has had many little things fixed since I have had it it drives much better and runs almost as good. The current phase I'm in now is to install the parts I have hunted down mostly on the classifieds here. Such as a uncracked valve cover. Evo8 valve springs and retainers (once I find cams) poly motor mounts. And drop the trans and replace all of the seals that I got off extream psi. And install the boost solenoid and run the boost control off ecmlink. Should keep me busy for a while.
