- Year
- 1996
- Model/Trim
- Mitsubishi Eclipse GSX
- Turbo Type
- 50-trim
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- PTE 5031re, Punishment Racing ss o2 housing, Megan Racing ss 3" dp, Megan Racing ss 3" cat-back, fmic, Tial Q bov, Taylor Thundervolt 50 wires, Dynatek Arc-2, FP intake, 9" K&N filter, Air box, ECMlink-controlled IR mbc, JMFab welded up valve-cover, JMFab deluxe catch-can, JMFab deluxe coolant reservoir, Fel-pro permatorque h.g., 3" GM maf, FP exhaust manifold, Magnus smim, 1g n/t throttle body, -8AN proclassic fuel feed, Fuelab 818 filter, Walbro 450, FIC fuel rail, -6AN proclassic fuel return, , Bluemax 1450's, Fuelab afpr, Earl's in-line oil filter, Mishimoto x-line radiator, (2) spal 12" slim fans, grounding kit
- Mods-Engine
- 2.3L (Carrillo, Wiseco, ARP), HKS 272's, Built head (Supertech, 1mm over)
- Mods-EMS & Logging
- ECMLink v3, AEM boost gauge, AEM eugo wideband, AEM 3.5 bar map sensor, Greddy turbo timer
- Mods-Drivetrain
- Shep stage 4, SBR shift kit, MR short shifter, Quarter Master gear-drive twin disk, skateboard bearing bushings, Frontline Fabrications rear diff cover, aluminum rear diff bushings, aluminum carrier bearing bushings, aluminum subframe bushings, evo 8 enkies with Sumitomo HTR+ 235/45s
- Mods-Handling
- Prothane mounts, Ground Control springs with Tokico Illuminas, hardware store rear camber kit
- Parts Wishlist
- Bigger turbo (FP Black?)
Better tires (Dunlop Direzza ZII Star Specs?)
