mitsu_matt's Eclipse GSX
Mitsubishi Eclipse GSX
Mods-Engine
4G63 6 bolt swap, 2.3 stroker, OEM 100mm crank with micro polish, ACL race bearings, Eagle stroker rods, Wisco 8.8:1 pistons, ARP main bolts, ARP head bolts, Cometic head gasket, 1G head with mild port on both intake and exhaust, 5 angle valve job, BC 1mm over valves, Bronze valve guides, BC titanium springs/retainers, HKS 272 cams, AEM adjustable cam gears, Power Enterprises timing belt, Balance Shaft Eliminator Kit, Earls -8 side mount oil cooler, Misimoto radiator with slim fans, Green top CAS, JMFab catch cans.
Mods-EMS & Logging
ECMlink V3, Hallman PRO Boost Controller, HKS turbo timer, Auto Meter EGR gauge, AEM wideban, Defi; Oil press, Water temp, Boost gauges.
Mods-Drivetrain
ACT 2600 6 puck race disk; ACT Streetlite flywheel, DriveShaft Shop front axles, B&M Short throw shifter, energy suspension shifter bushings, Billet cable bushings.
Eibach 2" Pro-kit, AEM Big brakes front & rear, 18x9.5 Enkie RS-6 Aluminum wheels; Nitto NeoGen 225/45-18 tires.
Parts Wishlist
Shepard Trans Foo!
1/8 Mile E/T
8.358
1/8 Mile MPH
83.500
Timeslip Details
Track Name : Milan Dragway
Fuel Used : Pump gas
Tires : Street Radials
348.4 lb/ft
Dyno Type
Mustang Dyno
mitsu_matt
More in 2G DSM
Share this Vehicle
