- Year
- 1997
- Model/Trim
- Mitsubishi Eclipse GSX
- Transmission Type
- Manual
- Mods-Bolt-on
- K&N filter element / FP Cast aluminum intake tube / Old school FP green turbo / Greedy electronic boost controller / Apexi FMIC and short route steel hard pipes with Extreme PSI silicon couplers and T-clamps / External 38mm Tial wastegate / Tial BOV / Walbro 255 fuel pump / B&M fpr / 660cc Denzo injectors / BJ's polished SMIM / Stock TB / NGK 7mm spark wires / NGK spark plugs / Turbo Back 3'' Megan Racing Exhaust / Megan Racing o2 housing / Balance Shaft Eliminator Kit / RRE Oil Catch Can / RRE Prothane Motor Mounts / Optima red top battery / RRE black silicon vacuum lines
- Mods-Engine
- 6 bolt longblock swap, build by English Racing / Wiseco HD 1400 Forged Pistons 9:1 compression / Eagle H-Beam Rods / ARP Head Studs / OEM Crank / ACL Race Bearings / Head upgraded with GSC valve springs, TI retainers, Chromoly seats, Supertech valves with the 4-angle intake valve grind and the 4-angle radius exhaust valve grind / HKS 272 intake and exhaust cams / HKS adjustable cam gears / Cosmetic hg /
- Mods-EMS & Logging
- DSM link v3 on Speed Density/ Auto meter Cobalt Boost, Egt, Oil pressure gauges / Apexi Turbo Timer / Innovative MTX-L wideband gauge
- Mods-Drivetrain
- ACT 6 Pad Spring Race Disk #6224704 / ACT Extreme Pressure Plate #MB010X / Stock Flywheel / Braided Stainless steel clutch line / OEM throw out bearing / Sheppard Stage 4 Transmission, with Evo III first gear and input shaft, EVO III fifth gear, 4-spider center differential
- Mods-Handling
- Totika springs and shocks / Megan Racing front and rear strut bars / RRE Front camber correction kit / Les Schwab Rear camber correction plates
Sparco 5pt harness on driver and passenger side / Cross seatbelt roll bar
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Timeslip Details
- Fuel Used : Pump gas
- Dyno TQ
- 323.7 lb/ft
- Dyno Type
- DynoJet
- Dyno Shop Name
- English Racing
- Dyno Session Details
- Nitrous : No Nitrous
Turbo : Old FP Green
Boost : 26
