Please Support JNZ Tuning
matt98eclipse's Eclipse GSX
Mitsubishi Eclipse GSX
2g throttle body elbo, Ebay header flanged for 38mm, 38mm external wastgate,SS turbo feed line, Big H1C holset turbo, Custom 3inch exhaust, Custom FMIC 32/12/3, Greddy catch can, Greddy type S Bov, custom intake, Walbro 255 fuel pump, Delphi 1150cc injectors, Aeromotive AFPR, NGK spark plug wires, NGK 6es plugs...... E85 fuel!!
Mods-Engine
Built Short block with arias 8.7.1 comp 20 over 6 bolt pistons, eagle h beam rods. ACL race bearings ARP studs.oem copper sprayed head gasket. 90 OFH with oil cooler.
HEAD,
Ported and polished, Bc 280 cams, crower titainum retainers and springs, Crower intake and exhaust valves, head milled. New valve seals.
Mods-EMS & Logging
Dsmlink, speed density, IAT and 3 bar MAP sensor. Socketed Eprom ECU, AEM uego wideband, autometer Boost, trans temp, Oil pressure at OFH and pre turbo, water temp gauges
Mods-Drivetrain
XTD 6 puck disc clutch, Welded center diff, fresh rebuilt tranny,
2"inch drop springs
Parts Wishlist
fully built bottem end!!!!
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
0.0 lb/ft
matt98eclipse
More in 1G DSM
Share this Vehicle
