Please Support Rix Racing
logic's Eclipse GSX
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Turbo Type
GT30 Variant
Drivetrain
AWD
Build Type
  1. Autocross
  2. Road Course
FP 3052 turbo
Tial 44mm wastegate
DV/DT intake
DV/DT FMIC
TiAL 50mm BOV
GM MAF and translator
Ported Cyclone intake manifold
Ported Evo III exhaust manifold
-10AN/-8AN fuel feed/return
ATL 15-gallon fuel cell
Dual Bosch -044 fuel pumps and Paxton 10-micron filters
Aeromotive Pro-Series FPR
Victory Performance fuel rail
Custom turbo-back exhaust
1990 oil filter housing with oil cooler
Relocated oil filter + 2qt. AccuSump
Power steering cooler
DIY COP + MSD DIS-2
Venom adjustable cam gears
Relocated battery
Other miscellaneous stuff
Mods-Engine
Engintecs-built 2.4L 4g64 6-bolt block w/Wiseco custom 9:1 pistons and Oliver billet rods
Engintecs-built 1g ported head w/FP3 cams, dual valve springs, stainless steel oversize valves, other miscellaneous valvetrain work
No balance shafts
Kiggly crank sensor
Prothane motor mounts.
Mods-EMS & Logging
DSMLink
HKS EVC EZ II boost controller
APEX'i turbo timer
Stewart-Warner 30-0-35 boost gauge
AEM UEGO gauge-type wideband O2
Mods-Drivetrain
QuarterMaster twin-disc clutch
7.25" chromoly flywheel
DSS L5 axles and hubs
Front/rear strut bars
Front lower stress bar
Front/rear RMDSM sway bars
DIY adjustable front sway bar end-links
Symborski shifter plate bushing kit
"Don Greenwood" brass under-hood shift cable bushings
B&M short-throw shifter
17x9+27 Team Dynamics Pro Race 1.2 anthracite wheels
Falken Azenis RT-615 255/40/17
Aluminum/steel rear differential bushings
Prothane rear control arm bushings
Koni "yellows" with Koni coilover sleeves and Hypercoil springs, RRE upper bearing plates
Evo brakes
Parts Wishlist
Spherical bearings for the front lower lateral control arms
Dogbox
Stronger transfer case
CF driveshaft
Tubular rear subframe
Background
It was my daily driver, and then it crankwalked. And then, "while I'm in there" set in. Now, it lives in a storage unit, waiting for me to get a garage again to work on it.
logic
More in 2G DSM
Share this Vehicle
