- Ownership Status
- No Longer Own
- Year
- 1992
- Model/Trim
- Plymouth Laser RS Turbo AWD
- Turbo Type
- 50-trim
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- PTE 50 Trim, fuelab fpr, FMIC, 63mm uber boost seals half shaft modded, wally 255lph hp punched releif rewired
- Mods-Engine
- N/A Block 40 over (no oil squirters) Ported head valve grind -- Delphi 1250cc injectors -- DkS Cams 272 intake 264 exhaust -- JE pistons 40 over -- Manley rods -- 3g lifters (revised) -- Cometic head gasket -- balance shaft delete -- ARP head studs -- ACL RACE rod bearing -- N/A water neck and pipe -- NGK plug wires -- NGK bpr7es plugs
- Mods-EMS & Logging
- eprom ecmlink v3 -- AEM wideband
- Parts Wishlist
- TRE tranny,
