Street Build Jtdsm400 2G Eclipse GSX
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Turbo Type
16g
Build Type
  1. Street
Forced Performance Manifold, EvoIII 16G, FP 4 Intake, Tubular o2 Housing W/ External Tial MVS 38mm, Custom 3" Exhaust; Mandrel Turbo Back Exhaust, VRSF FMIC, HKS SSQV gen3, FIC 1050cc Injectors, Fuelab Black Mini Regualtor, -6an Russel ProClassic Tank to Rail Feed Line, Walbro 255LPH(High Pressure), Prothane Driver & Tranny Mounts, black_gst Front Poly Mount, Converted 1G Aluminum Radiator w/ 2 12" Slims, Hallman Pro MBC
Mods-Engine
6 Bolt (8.5:1 Wiseco 1400HD Pistons, Manley H-Beam Rods), Kiggly 6-Bolt Crank Trigger Sensor, Stage 4 P&P 3-Way Cylinder Head, SS Valves, Bronze Valve Guides, Evo 8/9 Beehive Springs, Revised Slash 3mm Lifters, HKS 264/272 Camshafts, ARP Head Studs, 90 Oil Housing w/ External Oil Cooler, Balance Shaft Elimination Kit w/ Mitsu metal spacer
Mods-EMS & Logging
Dsmlink V3 Full, 3" Gm MAF, GM 3Bar, GM IAT, AEM Wideband, Cobalt A/F Gauge, Cobalt Boost Gauge, Cobalt Digital Voltmeter Gauge
Mods-Drivetrain
Stock Tranny,
ACT 2600 Clutch
ACT Streetlight Flywheel
Underhood Aluminum Shifter Bushings
Symborski Kit
SS Clutchline
KYB GR-2's,
Megan 2" Lowering Springs
Russell SS Brake Lines
Parts Wishlist
Black_Gst: Rear Subframe Bushings, Rear Differential Bushings, RM Sway Bars, Full Poly Suspension Kit, Methanol Injection, Slicks
1/8 Mile E/T
8.176
1/8 Mile MPH
84.040
Timeslip Video Link
Watch Video
Timeslip Photo Link
Timeslip Details
Track Name : KCIR
Nitrous : No
Fuel Used : Pump gas
Vehicle Weight : 3200
Tires : Street Radials
Sponsored Car : no
290.0 lb/ft
Dyno Type
DynoJet
Dyno Shop Name
Modified By Kc
Dyno Session Details
Nitrous : No Nitrous
Turbo : EvoIII16G
Boost : 20
Videos
98 Gsx Track Run 12.88 at 104
98 GSX: Stock 7bolt, 14g - 20psi, FP Manifold, Full 3" TB (No Cat, No Res), Ecmlink V3, VRSF FMIC, Walbro 255hp
eclipsetuner_21
Comments
More in 2G DSM
Share this Vehicle
