jed344's Eclipse GSX
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Turbo Type
HX40
Drivetrain
AWD
Build Type
  1. Street
Tial Q 50mm Bov,
6an feed, fuel lab fuel filter, 1g rail with xs power FPR.
Walbro 525 with bulkhead fitting
mac boost solenoid
3in V band exhaust to hks mufler
Morrison fab t3 open scroll hot parts kit
Tial mvs 44mm
Turbo lab 62mm hx40 with .82ar housing
-12AN oil drain
FP 4in intake pipe,
stainless steel oil feed line,
Jmf race Intake manifold
S90 70mm throttle body
VRSF FMIC,
Koyo 1g radiator
FAL 12in fan
FIC 2150cc injectors
JMF brake fluid cap
Vibrant Sealed catch can, 2 -10an lines from valve cover, 1 -10an to intake
Prothane motor mounts
E85
Megan racing strut bars
Dynatek ARC-2
Frontline Fab COP plate with 300M coils.
EVO 3 oil filter housing
B&M oil cooler
Mods-Engine
Split thrust 7 bolt
Arp mains
Evo crank
Pauter X beam rods
Weisco Hd 10:1 pistons
1/2 filled block
Arp L19 head studs
Oem composite
O ringed head
Ported
1mm+ valves
Kiggly high pressure springs
Revised lifters
Kiggly HLA
GSC S2 cams
Fidanza cam gears
Mods-EMS & Logging
autometer- oil pressure,
autometer- boost,
autometer- water temp
AEM x series wideband
HKS type 1 black turbo timer,
ECM link V3 Full
Mods-Drivetrain
Act 2600 with sprung 6 puck
Master to slave SS line
Tokico Strut/Spring combo
Enkei RPF1 17x9 +35
Hankook ventus v12 evo 2 245/40/17
Dimpled and slotted rotors
Parts Wishlist
Built driveline, twin disc clutch, Magna fuel 750
Background
Auto body tech. Used to build diesel trucks, Build and tune local dsms.
jed344
Comments
More in 2G DSM
Share this Vehicle
