- Ownership Status
- Currently Own
- Year
- 1995
- Model/Trim
- Eagle Talon TSi AWD
- Transmission Type
- Manual
- Build Type
- Street
- Drag Race
- Mods-Bolt-on
- Doc Race Manifold, GTX3582R, 3" Downpipe, Turbosmart WG45 , ID1000's, AEM e85 Intank Pump, Aeromotive FPR, Fore SS Fuel Filter, FP Intake Pipe, EVO 3 Intake Manifold, Thermal Exhaust, VRSF FMIC, 1G TB W/ High Boost Seals, Calan VS2 Catch Can, Koyo 1G Radiator w/ dual Spal Fans
- Mods-Engine
- Real Street Performance Built 2.3L 6 Bolt Stroker w/ 7 Bolt Head: CP 85.5mm 9.0:1 , Eagle 100mm Stroker Crank, Brian Crower H-Beam 625+ Rods, ACL Bearings, ARP Main Studs, GSC S2 Camshafts, ARP Headstuds, Mitsubishi EVO 3 MLS Headgasket, AEM Cam Gears, BC Valve Springs & Retainers, GSC Zero Tick Lifters, Supertech Valve Guides & Seals
- Mods-EMS & Logging
- AEM Series 2 w/ Flex Fuel. AEM Inline wideband. AEM Boost control, Kiggly Crank Trigger
- Mods-Drivetrain
- Southbend B-Series Ceramic , Comp Clutch Steel Flywheel, ARP Flywheel Bolts, Solid shifter base and cable bushings
- Mods-Handling
- Koni Sport (Yellow), H&R Springs, EVO 8 Enkei's on Hankook V12 235/45's
