- Ownership Status
- Currently Own
- Year
- 1996
- Model/Trim
- Mitsubishi Eclipse GST
- Turbo Type
- GT35 Variant
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- DNP exhaust manifold
rebuilt Hx35 with Bullseye Performance hotside
Tial 38mm w/screamer pipe
Apexi 3" turboback
Aluminum radiator
Big front mount
eBay knock off bov
FIC 880cc injectors
rewired Walbro 190
Fuellab AFPR
- Mods-Engine
- Head hot tanked rebuilt, and pressure tested with new stainless valves
BC springs
BC272 cams
Fidanza adjustable cam gears
1g CAS
NGK BPR 7es plugs
Evo9 pistons and rods
New OEM rings
New ACL Race main and rod bearings
Cometic HG
ARP head studs
All new timing components, with gates water pump and timing belt.
- Mods-EMS & Logging
- Dsmlink v3 with speed density setup
Apexi AVC-r electronic boost controller
Glowshift boost/oil pressure gauges
AEM wideband
- Mods-Drivetrain
- Fidanza lightweight flywheel
ACT2600 6 puck
OEM TOB
- Mods-Handling
- Black 99 GSX wheels
Dunlop Direzza z2
Eibach lowering springs
- Parts Wishlist
- New motor mounts
Improved radiator fan/shroud setup
New turboback
