- Year
- 1995
- Model/Trim
- Mitsubishi Eclipse GSX
- Transmission Type
- Manual
- Mods-Bolt-on
- Bulleye T04B V-trim | Aeromotive AFPR | Walbro 255hlph | DSMLink | PTE 680CC | AGP short route FMIC | Tial BOV | Greddy E-01 | Fidanza flywheel | Spec Stang 3 clutch/pp | FP flywheel install kit | FP 4" intake | K&N cone | Prothane motor mounts | SS oil feed & return | Earl's inline hi-flow fuel filter | dual 12" slimline fans | 6an SS pump to rail lines | Boost/vac | EGT | oil pressure | water temp | fuel pressure | fuel pump rewire | No A/C | No emission | No cruise control | no PS cooler | ported EVO o2 | Thermal R&D turbo-back 3" SS exhaust | ported and probed 2g mani | CF hood
- Mods-Engine
- 6bolt | 1g rods | 2g pistons | 3 angle ported head | balance shaft elim | HSK 272/272 cams | Power enterprises kevlar timing belt | Supertech Double valve springs | Hayame Cam Gears | 3/4" custom phenolic intake spacer | Mighty Max oil filter housing | Mitsu metal HG | ARP hardware
- Mods-Handling
- Energy Suspension poly master kit | Tockico HP strut s | Ground Control Coil overs | Progressive Camber kit | Fittipaldi Design Force 17X8 | Falken 235/45/17.
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Dyno TQ
- 0.0 lb/ft
