- Year
- 1995
- Model/Trim
- Mitsubishi Eclipse GSX
- Mods-Bolt-on
- MHI TD05h-18g, 3" fully welded custom IC pipe, 1g BOV (crushed), 550cc Lucas Precision injectors, 1g CAS (green top), Intrepid COP ignition, Supra Mk4 SMIC, custom 3" exhaust, rear washer sprayer converted to an IC sprayer, custom designed water injection system (400cc/min @ 200psi, 2 stage).
- Mods-Engine
- Cylinder head/Manifolds/O2 housing ported and polished. EGR/Emissions equipment deleted. Custom GP35N hardened steel head studs.
- Mods-EMS & Logging
- 98 H8 ECU Flash with SD CeddyMods 1.9vC SD.
- Mods-Drivetrain
- Fidenza lightweight flywheel, F1 Stage 3 sprung 6 puck clutch, solid motor mounts.
- Mods-Handling
- Custom PMC-790 90a urethane rubber bushings, 1/2 turn cut OEM springs (done right, cold formed spring to seat) 1.5" drop, Hawk ceramic brake pads, front and rear upper strut tower braces, front fender braces welded in place, stitch welded front chassis.
- Parts Wishlist
- A/W long flow IC, something stronger than the damn GSX 5 speed.... Auto maybe...
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Dyno TQ
- 0.0 lb/ft
