Street Build guseclipse's GSX
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Turbo Type
T28
Build Type
  1. Street
FP Big T-28, FMIC, NXS mbc, RRE downpipe, 3" test pipe, 3" SRS cat back exhaust, injen knock off intake, evo 3 o2 housing, evo 3 intake/exhaust manifold, PTE 1000cc injectors, AEM fuel rail, carbon fiber hood
Mods-Engine
Evo 8 springs/retainers, evo 8 pistons, ACL race main and rod bearings, ARP head studs.
Mods-EMS & Logging
glow shift boost gauge, apexi turbo timer, 99 ecu re-flash.
Mods-Drivetrain
SPEC stage 2 clutch, fidanza flywheel, prothane motor mounts, rear diff bushings, rear subframe bushings, rear control arm bushings, Evo 8 rear lsd swap
eibach lowering springs, TOKICO 5 way adjustable shocks, cross drilled sloted rotors, evo 8 enkies, evo 8 rear calipers.
Parts Wishlist
Evo 8 front calipers, Evo mr bbs wheels, Carbon Fiber Hatch, HKS 272 cams, no smog in cali
Background
Push the t28 as far as it will go
1/8 Mile E/T
8.345
1/8 Mile MPH
99.345
Dyno HP
298.1 whp
298.1 lb/ft
Dyno Session Details
Turbo : T28
Boost : 21
guseclipse
Comments
More in 2G DSM
Share this Vehicle
