Please Support Rix Racing
GripNGo's Talon TSi AWD
Eagle Talon TSi AWD
Automatic
Build Type
  1. Drag Race
Mods-Engine
.20 over 2.0, balance shaft elimination kit, polished crank, Eagle H-Beam rods, Eagle 3/8 rod bolts, Forged 8-5-1 Ross Racing pistons, ACL race tri-metal rod bearings, ACL race tri-metal main bearings, ARP main studs, ARP head studs, RACE FMIC, CB built head, Precision SCM6152-S trim turbo, HKS 272 i/e cams, HKS cam gears, HKS kevlar timing belt, FP race manifold, FP evo3 o2 housing fully ported, 3 inch Thermal RD turbo back exhaust, Magnecor 8.5mm wires, dual FAL slimfans, Gates Racing coolant hoses, Fluidine Pro rad, Cometic bottom end gasket kit, Cometic MLS head gasket, GM MAS, MAF translator, FIC 1050cc injectors, Walbro 255 fp in tank, Aeromotive FPR, Bosch 044 inline, Fiberglass full open headlight intake, Greddy oil cap lol
Mods-EMS & Logging
DSM Link v.2, AEM Wideband, Apexi TT
Mods-Drivetrain
IPT shift kit, restalled torque converter, Translab valvebody, blue wire mod
Energy Suspension front end control arm bushing set,
Energy Suspension front sway bar frame bushings,
Energy Suspension rear end control arm bushing set,
Energy Suspension sub-frame bushing set,
Engergy Suspension rear sway bar frame bushings,
Energy Suspension tie rod boots,
DME rear camber adjustment kid,
Ingalls camber adjuster +/-2,
KYB adjustables,
H&R springs,
16x7 Rota Slipstreams on 225/50 R16 BFG G-Force tires
GripNGo
More in 1G DSM
Share this Vehicle
