- Year
- 1992
- Model/Trim
- Plymouth Laser RS Turbo AWD
- Transmission Type
- Manual
- Mods-Bolt-on
- Ebay $11 Manual Boost controller, egr block off plate,
SBR ported 2g ex. manifold,Magnus Intake Manifold, N/T throttle body stock with turbo seals, Holset HX-35 7blade, BEP .55 mitsu turbine housing, Punishment tubular o2 housing w/ 44mm Vband wastegate dump, walbro 255HP fuel pump, -6 feed line-6return to Areomotive FPR, Bosch 1600cc injectors, Speed Density, FP 4" intake pipe, Big K&N air filter, Punishment Racing FMIC kit, lightweight Odyssey 680 battery w/ JMF mount kit
- Mods-Engine
- Eagle rods, Ross pistons, ARP head studs, mains and rod bolts, Super Tech Dual springs with titanium retainers, BC272s, rear balance shaft removed
- Mods-EMS & Logging
- Auto Meter 30psi boost gauge, AEM UEGO wide band, dsmlink V3
- Mods-Drivetrain
- ACT 2600clutch, RRE lightened stock flywheel, solid shifter cable and base bushings, Mobil one gear oil in trans, 4 spider diff, evo shift forks, double syncros in 2nd gear, act 6puck unsprung
- Mods-Handling
- RX-7 FD wheels "gun metal" wrapped in 225/50/16 tires
Eibach Prokit springs, rear KYB AGX shocks, KYB GR2 front struts, Jays Toe eliminators, front eccentric camber bolts, rear upper ingals camber arms, polly bushings in front and rear sub frames, front lower control arms and rear sway bar, stainless braided brake lines, drilled/slotted rotors, dual piston front calipers, ARP extended wheel studs with drop engineering light weigh lug nuts
- Parts Wishlist
- Shep tranny, HX-35, sponsorship
- 1/4 Mile E/T
- 11.180
- 1/4 Mile MPH
- 127.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 1.700
- Timeslip Details
- Track Name : Capitol Raceway
Nitrous : No
Fuel Used : Race gas
Vehicle Weight : 2950
Tires : Slicks
Sponsored Car : no
- Dyno TQ
- 0.0 lb/ft
- Dyno Session Details
- Boost : 00
