1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
Please Support JNZ Tuning
Funfettie's Eclipse GST (AWD swap)
Year:
1998
Model/Trim:
Mitsubishi Eclipse GST
  • Ownership Status:
    I own it
    Transmission Type:
    Build Type:
    • Street
    Mods-Bolt-on:
    SBR FMIC, 2.5" SS piping intercooler piping, Evo10 10.5 split port MAP EF4 turbo, MAP custom manifold, o2 housing, and downpipe, 6 bolt TB, Magnus Intake Manifold, Custom Mandrel 3" exhaust , 2150cc FIC HighZ injectors, walbro 255 intank, walbro 255 inline, fuellab AFPR(E85), -6an stainless fuel lines, KCR 3k micron filter, 3" intake pipe, Calan Catch can, strut braces, R&M front sway bar, ram air headlight.
    Mods-Engine:
    6 bolt block, Eagle 2.3 stroker crank, eagle rods, Wiesco pistons (40over), ACL race bearings, ARP main studs, micro-polished and balanced rotating assembly, mirror finish machining, Commetic MLS head gasket, MAP H11 head studs, 6 bolt head, stainless valves, stainless springs/retainers, comp 100200 cams, port matched and polished.
    Mods-EMS & Logging:
    DSMlink v3 full, glow-sh** gauging., LC-1 wideband.
    Mods-Drivetrain:
    TRE 4th stage transmission, evo gears, 4 spider diff, quartermaster 7.25 twin disk clutch/flywheel, LSD rear diff
    Mods-Handling:
    Skunk2 coilover sleeves , KYB Gr2 struts, camber kit. XXR 527 wheels, stretched Nitto Neo Gen tires.
    Background:
    Built this car for 6 years. parted it out and happened to run across the shell for sale again early Jan 2016. Here starts chapter 2!
  • 1/4 Mile E/T:
    12.023
    1/4 Mile MPH:
    112.330
    1/8 Mile E/T:
    7.699
    1/8 Mile MPH:
    87.000
    60' Time:
    1.697
    Timeslip Details:
    Nitrous : No
    Fuel Used : E85
    Tires : Street Radials
    Sponsored Car : no
    Dyno TQ:
    300.0 lb/ft
    Dyno Type:
    DynoJet
    Dyno Shop Name:
    Modern automotive performance
    Dyno Session Details:
    Nitrous : No Nitrous
    Fuel Used : E85
    Turbo : MAPevo10 Ef4
    Boost : 32
Share this Item
User Comments
  1. rrussell
    Nice looking car!!! What brand is your catch can???
    1. Funfettie
      Its a Calan catch can, he's a member on tuners that makes them. www.jcsautomation.com
      Funfettie, Jan 30, 2016
    2. rrussell
      Cool. Thanks man!!!
      rrussell, Jan 30, 2016
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Miller Import Parts Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
