- Year
- 1997
- Model/Trim
- Mitsubishi Eclipse GST
- Mods-Bolt-on
- Garrett GT30r, Shearer T3 tubular manifold, Shearer O2 housing, Shearer dumptube, Tial 38mm wastegate, Accel plug wires, Apexi Dunk cat-back exhaust, Apexi N1 downpipe, DV/DT Fabrication FMIC, Dejon 3" Intake, Earl's external oil cooler, EvoIII oil filter housing, HKS filter, Magnus intake manifold, PTE 680cc injectors, Prothane motor mounts, PWR radiator, Samco Sport radiator hoses, Tial BOV, Turbo XS MBC, Walbro 255lph HP fuel pump, Weldon fpr, Weldon fuel filter, Russell -6AN fuel feed line from tank, ported 1g throttle body, Motul fluids, XRP HS-79 coolant hose.
- Mods-Engine
- Cosworth head studs, HKS 264/272 cams, HKS cam gears, HKS headgasket, HKS t-belt.
- Mods-EMS & Logging
- ECMLink V3 (Speed Density), Stack ST8130P digital dash display, PLX wideband, Defi boost gauge, AEM 3.5 Bar MAP, AEM IAT.
- Mods-Drivetrain
- ShepTrans Stage 2 trans- Double syncro 1st-4th, LSD; SPEC Stage 3+ clutch, Three Speed scatter shield, ACT flywheel, B&M Shifter, Redline Lightweight Shockproof.
- Mods-Handling
- Volk RE30 18x8.5, Zeal Function-X coilovers (spring rates- front: 12kg/mm rear: 8kg/mm); 24/64/18 Michelin slicks (track), 235/40/18 Michelin Pilot Sport Cup tires (street); Goodridge SS brake lines; Project Mu big brake kit: 355x32 rotors, Project Mu B-Force brake pads (front), Endless SS-S Sport pads (rear), Rotora OEM slotted rotors (rear), SPC forged aluminum upper control arms, Prothane front suspension bushings; ARP extended wheel studs, DV/DT Fab harness bar.
- Parts Wishlist
- Magnus fuel rail, built engine, go to the track!
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Timeslip Details
- Sponsored Car : yes
- Dyno TQ
- 0.0 lb/ft
