- Ownership Status
- Currently Own
- Year
- 1998
- Model/Trim
- Mitsubishi Eclipse GSX
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- Precision BB 6262 turbo, SwainTech coated SLS T3 tubular manifold, Tial 44mm wastegate, Tial Q BOV, ETS FMIC, Magnaflow catback, Zaklee Corp Clear Cam Gear Cover, HKS cam gears, HKS Purple Kevlar Timing Belt, COP ignition, EVO I intake manifold, STM heat barrier gasket, ported EVO VIII throttle body, Calan catch can, Kiggly HLA Pressure Regulator, Galant 90amp alternator, Mishimoto X-line radiator, Flex-A-Lite dual fans, Samco Urban Camo radiator hoses, Walbro 450lph, FIC 2150cc High Impedance injectors, Magnus fuel rail, FueLab 8AN fuel tank to rail kit, FueLab fuel pressure regulator, EVO VII Steering wheel, Sparco Monza seats, B & M short shifter, Greddy counterweight shift knob
- Mods-Engine
- HeadGames Motorworks 2G cylinder head, GSC S2 cams, 2.4L 4G64 long rod shortblock built by UCS Performance, 9.5:1 Wiseco Pistons, Manley Turbo Tuff's, ACL Main and Race Bearings
- Mods-EMS & Logging
- EVO VIII ECU, EVO X MAP Sensor, Grimmspeed EBCS, MadMsheen tuned with Speed Density, AEM UEGO Wideband Air/Fuel Ratio, Boost and Oil Pressure gauges
- Mods-Drivetrain
- Clutchmasters FX400, Avid Racing Billet Motor Mounts, Aluminum Rear Subframe -Drive Shaft Carrier and Rear Diff Support Bushings, Rebuilt Rear Diff by TRE
- Mods-Handling
- K-Sport Kontrol Pro Coilovers, Megan front and rear strut bars, Ingalls Front Camber kit, Full Brembos, Black EVO VIII wheels
- 1/4 Mile E/T
- 00.0
- 1/4 Mile MPH
- 000.0
- 1/8 Mile E/T
- 0.0
- 1/8 Mile MPH
- 00.0
- 60' Time
- 0.0
- Dyno TQ
- N/A lb/ft
